It is currently Mon Apr 12, 2021 8:16 am
PostPosted: Sun Feb 26, 2017 6:43 pm
Pictures, documents, printed materials, videos, catalogs, manuals, datalogging and ECU editing stuff .... and more, all now located here:
Click me
Current as of April 13, 2020.
PostPosted: Wed Aug 02, 2017 6:56 pm
administrator
The 3G 89-92 CSM Body Repair Manual is available at http://4g61t.org/archive/manuals/89%20c ... manual.pdf
Mirror of the other manuals is available at http://4g61t.org/archive/manuals/
Manuals are still listed at http://www.lilevo.com/mirage/
Major upload has occurred to add to what is there and a major reorganization of the file system.
Working on the final outcome, but for the time being, the above link is accessible.
PostPosted: Sun Apr 14, 2019 9:16 am
Have recently come across some updated versions of ASA.
Updated around the April 2018 to 2019 time frame. It doesn't get any newer at this point.
This can be good if it retains all the parts numbers that exist, versus parts numbers that are NLA in the OEM parts system. If numbers disappear, that would be unusual and bad all at the same time, so keeping older copies may be good at this point.
Regardless, these are accessible via the link below - but it is hosted likely in Russia. Russia was nice enough to supply the biggest set of worldwide ASA programs that we had access to some years ago, so I am quite thankful for that.
Here is the direct page where you can make your choices on what you need to use, to sort out your car or truck or van.
http://mmc-manuals.ru/Downloads
