It is currently Sun May 05, 2024 7:51 pm
Post new topic  Reply to topic  [ 74 posts ]  Go to page Previous 1 2 3 4 5
PostPosted: Wed Jun 10, 2015 10:04 am
New rims on with custom Eagle stickers, snow tires mounted (Michelin ice X) and going for her 1st drag race tonight!!!
PostPosted: Mon Aug 10, 2015 8:20 pm
SO I made a pretty good 1st run at IFO but still making crappy 60' times. I tried to tighten up the 60' and launched it harder and this was the result...
SO I was told that I needed non-greasable (solid) u-joints and the factory ones are solid. I bought a set of O.E. joints and they are greasable (hollow) like the one that broke. I am only running 195/60/15's but the car squats really hard on launch. What u-joints are the best or should I be using some other drive shaft parts????
Thanks,
PostPosted: Mon Aug 10, 2015 8:27 pm
Always OEM! Here is a good cheap way to get them, if you buy the u joint alone the price is really high. http://www.jnztuning.com/product_info.p ... ts_id=2243
PostPosted: Mon Feb 15, 2016 1:16 am
Yep the factory solid ujoints are the only way to go. The others will break. Buy the recall kit in link above. You basically get a free yoke with a ujoint vs buying oem ujoints alone.
PostPosted: Fri Nov 11, 2016 10:03 am
So took the Summit out a few times this summer. I was washing it for a import car show in July and noticed bubbles on the roof. Long story short I pulled the headliner and pulled down the supports to find the typical rust. not a fun project but all rust removed and I painted the roof inside and out then put the supports back in. No racing this year and I have yet to get it tuned but planning on it soon.
Mark
PostPosted: Thu Dec 08, 2016 4:24 pm
Getting ready to put the Summit up for the winter and took it for a short blast
https://www.youtube.com/watch?v=eQ48u1_lwXw
PostPosted: Sun Jan 01, 2017 1:25 pm
Took the Summit for it's 1st official tune at RRT motorsports in Canton CT. She put down 452 HP on his mustang dyno. Here is the video, enjoy!!
https://www.youtube.com/watch?v=R4mv0iJyHEY
PostPosted: Sun Jan 01, 2017 3:31 pm
Looks and sounds great!! Good work and love the wheels
'92 Evo 1
'10 CTS-V
PostPosted: Fri Apr 28, 2017 7:22 pm
So I drag raced the little blue car and noticed the hood gets hella hot. I thought up a idea and ran with it. I thought I posted it but do not see it so here is what I did. I cut the vents out of a MR2 hood and bought a new Summit hood. I marked the hood, cut out the rectangles and welded in the MR2 hood vents. Here are the pictures.
PostPosted: Fri Apr 28, 2017 7:27 pm
Finished product. I think I like it and it is not some stupid scoop. Still sleeper and since I did it to a different hood I can always throw the original hood back on!!
Enjoy
PostPosted: Fri Apr 28, 2017 8:45 pm
I dig it, nice work.
PostPosted: Fri Apr 28, 2017 9:47 pm
It turned out very well!
First large scale use of "slats", I've seen used on this platform. Seen use of smaller versions like Evo and Galant hood vents, but nothing ever this big. It works!!
PostPosted: Sat Apr 29, 2017 7:02 pm
most diy scoops make me want to puke. but i like these.
PostPosted: Tue May 02, 2017 2:12 pm
Very nice work as usual :wink:
