It is currently Thu Apr 25, 2024 10:01 pm
PostPosted: Wed Oct 12, 2016 8:55 pm
I found a rare manual expo/summit/vista shifter setup, it will include, the complete [meaning all springs and bushings] shifter base assembly, oem shifter accordion and knob,shifter cables, and the under-hood bracket with all washers and bolts, it was pulled from a 1992 expo lrv sport, I want to see this go to an expo/summit vista wagon owner, because I want to see more 4G63T examples of these vans :twisted: , i'm thinking at least around $50.00 [plus whatever shipping will be], I'll research that in the meantime.
Pictures will be up shortly.
Paypal is best form of payment, But best offer takes it.
Abe
PostPosted: Sat Oct 29, 2016 12:08 am
Probably be wise to go back and grab the clutch pedal assembly too if you can.
PostPosted: Mon Oct 31, 2016 10:02 pm
Yeah I'm planing on pulling the assembly I'll update this when I do.
Abe
PostPosted: Fri Nov 11, 2016 2:21 pm
can you get the manual tranny off it? I need one.
PostPosted: Sat Nov 12, 2016 9:17 pm
If you need a fwd trans, you can custom mount a turbo dsm F5M33, the expo I pulled the shifter from was a fwd example.
if your running an awd expo, you can use a fwd trans in place... that is just until you find an awd expo.
is your expo a 1.8 or 2.4?
Abe
PostPosted: Thu Dec 29, 2016 5:28 am
I added a clutch pedal and some other parts into the sale but made a post in the classifieds here http://www.4g61t.org/forum/viewtopic.ph ... 17#p324817.
Abe
Users browsing this forum: No registered users and 45 guests
