It is currently Thu Apr 25, 2024 9:51 pm
 Post subject: mpi relay
PostPosted: Sun Oct 09, 2016 10:16 pm
im looking for confirmation on if i need to swap out my existing mpi relay when using a 91+ dsm ecu currently i have the stop 1.6L turbo mpi relay installed. will this cause problems with my ecu or am i ok?
 Post subject: Re: mpi relay
PostPosted: Mon Oct 10, 2016 8:34 pm
Out of everyone here who's done a 4g63 swap nobody can confirm if they used the dsm or csm mpi?
PostPosted: Mon Oct 10, 2016 10:22 pm
If it plugs in and works then don't worry about it. They aren't expensive. Find a dsm one just in case.
Look up any of the wiring diagrams on my site. Find the MPI relay page. Print out both side by side. Compare.
PostPosted: Tue Oct 11, 2016 5:23 am
Thank you. Well hopefully I'll be doing a first start today I'm trying to get this done before the rain hits (a week or less). That's why I'm trying to sort out all my unforeseen issues before I get to them. As of right now the stock turbo csm mpi relay, power transistor, coil and resistor pack are being used.
PostPosted: Sat Oct 29, 2016 9:45 pm
Mine is running stock relay. 91+ motor . All I changed over was the coil and power transistor for a 90. The TB was whatever I had in my parts bin. I threw in an old used 14b. Cranked it over and hoped for the best!
I had no motor in my colt when I got it and I had to sort out the hacked wiring harness in the engine bay. I had no idea what connector did what.
In the end. It all works out.
One piece at a time.
DRCOLT
1989 3g Colt GT turbo w/4g63t
Users browsing this forum: No registered users and 30 guests
