It is currently Sat Apr 27, 2024 7:16 pm
Post new topic  Reply to topic  [ 50 posts ]  Go to page 1 2 3 4 Next
 Post subject: Swap started
PostPosted: Fri Jul 29, 2016 11:09 am
I have finally started.
http://s204.photobucket.com/user/drcolt ... dan%20swap
DRCOLT
1989 3g Colt GT turbo w/4g63t
 Post subject: Re: Swap started
PostPosted: Mon Aug 01, 2016 9:07 am
DRCOLT
PostPosted: Fri Aug 19, 2016 9:26 am
Locked in place.
DRCOLT
PostPosted: Fri Aug 19, 2016 9:44 am
Engine mounts used:
91-95 hyundai elantra 1.8 manual rear mount and engine bracket, and timing belt side mount.
Rear mount cross member holes had to be hogged out to suit elantra motor mount.
Front mount is stock colt and G32b bracket.
Tranny mount is stock colt and dsm fwd bracket.
Cv shafts used are stock colt . My motor is off a 90 dsm which had the halfshaft driver side. So far it all buttons up good.
Wiring looks to be pretty straight forward. Now it's on to do the plumbing.
Fit oil cooler.
Figure out shifters.
Fit in rad.
For now I am keeping power steering. Gotta look into a non power steering rack.
More to come.
DRCOLT
PostPosted: Mon Sep 19, 2016 6:32 pm
Its finally running.
Now i can clean up wiring inside the cabin.
I had a issue wih the alternator wiring where i couldnt stop the engine and it was putting out 18-19v.
It turns out the dsm and colt alternators operate differently.
I had to wire it as a dsm alternator, had to add the relay(which is really a resistor diode combo).
Now i can move the battery to the trunk, order ecmlink, and redo intake piping and plumb in intercooler and piping.
Pictures to follow.
Much thanks to Oscar, aka miragesist.
DRCOLT
PostPosted: Wed Sep 21, 2016 8:32 pm
Shifter temporary fix. I had to extend the arms about 1.5".
DRCOLT
PostPosted: Thu Sep 22, 2016 8:55 pm
Preliminary wiring.
Now that I know it works time to tidy it up.
DRCOLT
PostPosted: Thu Sep 22, 2016 8:56 pm
Slim fan.
DRCOLT
PostPosted: Thu Sep 22, 2016 9:03 pm
For the rad hoses I had to use a stock 4g61t Stat housing with no rad cap. It has a better angle to allow upper rad hose to fit. Upper rad was modified to 1-1/4" outlet instead of the 1".
Upper rad hose used was whatever I found at parts supplier that had the bends close to what I needed and cut to suit.
Lower rad hose was simply a dayco 20" flex coil hose.
DRCOLT
PostPosted: Thu Sep 22, 2016 9:07 pm
Alternator issue addressed. I had the alternator looked at and it needed a new regulator.
Used stock wiring, but had to add the dsm alternator relay which is actually a diode and resistor. That is what allows the engine to turn off.
DRCOLT
PostPosted: Fri Sep 23, 2016 3:50 pm
Exhaust done.
DRCOLT
PostPosted: Fri Sep 23, 2016 3:53 pm
Motor running without intercooler.
Battery needs to be relocated to make room for some neat intercooler piping.
DRCOLT
PostPosted: Fri Sep 23, 2016 9:51 pm
this is cool, keep us posted
PostPosted: Sat Oct 08, 2016 6:59 pm
Installed starion fmic. Very tight fit. Still waiting on battery relocation kit. Move battery to trunk, also waiting on gm maf and maybe translator before getting ecmlink.
Had to customize the turbo neck to suit. I don't like it going over the manifold, but I have no choice
DRCOLT
PostPosted: Sat Oct 08, 2016 7:00 pm
Running 10psi for now. I need to upgrade fuel pump and injectors
DRCOLT
