It is currently Wed Apr 24, 2024 1:18 am
 Post subject: Will these fit my C53A?
PostPosted: Wed Aug 17, 2016 9:26 am
http://www.ebay.com/itm/111913043876?_t ... EBIDX%3AIT
PostPosted: Wed Aug 17, 2016 8:06 pm
I want to say yes .. but more likely probably. I do bet they reused the bolt spacing, so it is just a matter of how much caster is built in, and how wide the plates are for fitment in the upper strut tower. Worst case, a little attack of the grinder that no one will ever see. There are guys using EVO1-3 stuff ... hopefully they will chime in.
PostPosted: Wed Aug 17, 2016 10:51 pm
hope this helps corey.
these are fortune auto coils for an evo 111.
previous owner said you would have to lightly elongate the holes in the fender
for the mounting studs. i cant confirm cuz no time to go out and play with car.
just take this info and compare to your csm.
no camber seems to be the biggest bummer.
5-3/4 center to center for mounting studs
just shows the strut shaft is centered between mounting studs so no castor built in
approx size needed to fit in the center hole of the fender opening (should be fine there)
with in the other direction for fitment underneath fender (should be fine there too)
PostPosted: Thu Aug 18, 2016 4:32 pm
aussie cars have camber plates on their CSM not sure though if those were teins or cusco
PostPosted: Fri Dec 02, 2016 12:08 am
I been looking at those for quite some time but i havent bit the bullet
PostPosted: Sat Dec 03, 2016 12:25 am
If the early EVOs share the 4g mirage chassis, then the studs should be around 10mm closer together than the 3g CSM plates. I know from modding the 4g strut brace to fit my 3g Colt.
PostPosted: Sat Dec 03, 2016 4:22 pm
yup seems about right. the owner of the evo3 coilovers from the pics i posted above said he had to elongate the holes a bit in the csm fender mount area. the measurements are there to if anyone wants to compare to their csm.
PostPosted: Mon Dec 05, 2016 1:03 pm
I'll take a bet that the EVO3 top plates shown, could be interchangeable with the KSport top plates I got with my C50 platform coilovers. All it would take is a measurement of the distance between the camber adjust bolts from side to side along the same plane. Then you know if it will bolt up to KSport top cups. For those not wanting to cut their chassis.
