It is currently Wed Apr 24, 2024 11:55 am
Post new topic  Reply to topic  [ 57 posts ]  Go to page Previous 1 2 3 4
PostPosted: Sun Oct 11, 2015 10:53 am
Well I have come across some Scion tC 16x6.5 5x114.3 +45 offset steel rims
Would these work?
PostPosted: Sun Oct 11, 2015 5:40 pm
Yes they will work
PostPosted: Tue Apr 05, 2016 5:29 pm
I run 225/50 tires on 16x7 wheels with +40 offset. My car is slammed in coil overs and the wheels are tucked in the fender still. However I did have to remove the front inner fender liners and roll the fender lip. It's a tight fit when lowered.
True, ... true.
Got 1970 SS ?
PostPosted: Tue Aug 09, 2016 8:53 pm
would a 15x6.5 and 38 offset w// multi lug pattern fit our CSM captive rotors? My other options is 16x7 w/ 45 offset and also a multi lug. Among the options w/c is a better
PostPosted: Tue Aug 09, 2016 9:52 pm
I would go with the first choice for a better fit. But both will fit decent. Its the center bore you may have to measure to be sure they will fit
PostPosted: Tue Aug 09, 2016 10:07 pm
What brakes are you running?
If you have the stock base model solid front rotors and drums in the rear, I don't recommend adding upsrung weight to the front and rear of the car, as 100% this will.
Acceleration will be slower, as will deceleration, with only cornering being a bit better assuming you haven't moved the wheels too far in or out.
If you have turbo brakes, disregard as it is less of a concern.
PostPosted: Wed Aug 10, 2016 12:12 am
the bore size says 72.6
also does a 38 offset better than 45? based on the post above 40+ above is a much better choice
PostPosted: Wed Aug 10, 2016 8:47 am
Depends on your wheel width and tire size, we cant tell you to go with +38 or +45 based on nothing. I personally like a slightly lower offset and run +34 on 15x7 225/50s but they are more like 235s as the tire I use runs on the big side, I had to roll the front fenders.
PostPosted: Wed Aug 10, 2016 6:48 pm
im just worried if the +38 wheel be out sticking out of the fender or hit something inside the suspension on full turns compared to +45. what's the limit on tire size can the +38 offset handle im planning on 195/50 can it handle 205/50 or 205/55? what about the +45 tire size choices?
PostPosted: Thu Aug 11, 2016 7:41 am
A 205/50 would be a good fit for +38.
PostPosted: Mon Sep 12, 2016 1:01 pm
im looking for wheel offset options of +38 ,40 or 42 which is the best to go among this 3 on 15's
PostPosted: Tue Sep 13, 2016 12:02 am
Any of them are fine
Users browsing this forum: No registered users and 27 guests
