It is currently Wed May 08, 2024 9:52 am
PostPosted: Mon Jul 04, 2016 11:53 pm
woot woot i got swede density and after reading a whole lot of stuff its a lot to take in especially for a person not used to using tuner pro rt. but man im like it though well labeled loads of stuff we all like that.im gonna try to get the car tuned this friday at the track hopefully. still have to get few things (dont ever buy arp turbo bolts.save your self a headache) oem bolts gonna get ordered.
PostPosted: Wed Jul 06, 2016 11:18 am
Kim hooked you up, glad to hear it!
Get the washers OEM, from Mitsu for the turbo bolts and the highest temp anti-seize with Nickel or the Nuclear grade (no copper), and apply it after tapping out your holes. Just enough to keep them from seizing and not enough to make your torque values go way off. Best advice I could give you to keep the turbo tight with heat cycling and to keep the bolts from galling/seizing and possibly snapping upon removal - should you need to. The washers are not cheap (x4) but you HAVE to use them.
PostPosted: Thu Jul 21, 2016 5:27 pm
Swede density? Didn't know they had their own setup... :lol:
PostPosted: Fri Jul 22, 2016 1:01 pm
http://www.kaxlon.com/
There is a development site but it requires permission to join and is for very techie minded folk. I suppose if you can operate TunerPro/Jackal/etc, then you are off to a good start.
