It is currently Mon May 06, 2024 11:27 pm
Post new topic  Reply to topic  [ 160 posts ]  Go to page Previous 17 8 9 10 11
 Post subject: Re: Dodge colt gt 89
PostPosted: Mon Sep 07, 2015 8:41 am
I run a de-powered rack on the road course (The Ridge) 20min. sessions it's not bad at all, hell it might even improve feel and feedback. However if you run a very soft compound or slicks you might be sore the next day. :)
PostPosted: Mon Sep 07, 2015 7:53 pm
Y......e.....s!!! So fresh and so clean.
PostPosted: Tue Sep 08, 2015 6:11 am
@ Nocturnal: I'm fine with your mind finally, i use Yokohama Advan A048 medium compound. This tires picks up all the gravel on the road really :D
@ Tim: Thanks you my friend. The Colt come back soon to the body shop for body retouches for free, some imperfections from the last work.
I need to take better pictures i know that, I'm happy really to see this project running finally :wink:
PostPosted: Wed Sep 09, 2015 1:58 am
Last pics
PostPosted: Mon Oct 19, 2015 11:20 pm
nice
PostPosted: Sat Oct 31, 2015 4:38 pm
The last paint work i hope, details corrections and final polishing :D
PostPosted: Mon May 02, 2016 5:51 pm
So Remy, how is the car running right now?
Any good happy points and any points you would want to change?
PostPosted: Wed May 04, 2016 3:38 am
Hi Tim.
The Colt could be tuned this month weather temp depending.
Good :
-Better feeling with the Koni's now, turn fast and still comfortable.
-It pull hard at 15 psi with s16G, logged 22lb/m. Goal is 20 psi or more with ecmlink boost control function.
Bad :
-Blue smoke sometime, maybe from the rebuilded s16G. I need to find why before tune.
-The turbo hit full boost at 3400 rpm, the 43cc big port head/ FP manifold/ 7cm turbine housing combo is not the best idea with the 1.6 bloc ...
More to come my friends :D
PostPosted: Wed May 04, 2016 7:27 am
3400 rpm not bad for a 1.6. My 1.6 s16g is 4000rpm full boost, evo3 exhaust mani, shimmed and over preloaded internal wastegate, 7cm turbine housing but stock exhaust.
PostPosted: Wed May 04, 2016 7:24 pm
Ah, the blue cloud! Hmmmm ....
On the bright side, that is fast spool compared to my old 1.6 with 1G DSM upgrades strapped to it.
