It is currently Fri Apr 26, 2024 10:50 am
PostPosted: Tue Apr 26, 2016 6:56 pm
Hi,
After many long years. my swap is finally done.
1992 Expo SP 5MT AWD.
just a 4G63 swap off a 92 talon.
N23W RVR Esepelir springs on 1G KYB AGX.
PostPosted: Wed Apr 27, 2016 1:28 am
Nice! What are your plans with it?
PostPosted: Wed Apr 27, 2016 12:53 pm
Initial plan was to build a 4G64 block with 4G63 head and build a reliable 300-400WHP daily driver since this car came with the 6 bolt 8V 4G64 engine.
But due to budget reasons, just decided to throw in the 6 bolt 4G63T with stock everything for now as the engine was running well off the parts car.
Its going to be my daily driver for a little bit and upgrade as I go (or when things break)
PostPosted: Mon May 02, 2016 1:43 am
what did you do for wiring ?
PostPosted: Mon May 02, 2016 3:07 pm
I merged the factory Expo Harness with my 92 Talon harness.
All the factory functions is maintained. Only thing I haven't tested is the AC. As the Talon has a dual pressure switch and the Expo has a triple pressure switch. So I'm not sure if it will work.
I have some hand written notes I can post up to show which wires from the Talon harness should connect with the Expo factory wires if you need anymore info.
PostPosted: Mon May 02, 2016 7:04 pm
That would be awsome..
PostPosted: Tue May 31, 2016 8:30 pm
I would appreciate the wiring notes also. Just dropped in my 4G63 T in my 1992 summit and need to do the wiring soon.
Richard Montalvo
- 1992 Galant VR4 AMG Swapped 615 AWHP
- 1989 Mirage Hatchback EVO Swap project
- 1992 Eagle Summit Van project
- 2011 Lancer Sportback 2.4L daily driver
- 2010 Mitsu L200 2.5 diesel pickup (work truck)
