It is currently Sat May 04, 2024 6:11 pm
Post new topic  Reply to topic  [ 272 posts ]  Go to page Previous 115 16 17 18 19 Next
 Post subject: Re: whe3ls's hyundai
PostPosted: Wed Nov 12, 2014 8:11 pm
thanks man, its been along time coming. i havent touched it. ill prolly mess it on friday maybe.
PostPosted: Fri Nov 14, 2014 9:31 pm
PostPosted: Tue Mar 31, 2015 11:30 pm
brand new HP Trans for the elantra
kill mode ;)
PostPosted: Tue Feb 16, 2016 12:43 am
Hey guys.... Im Back..
So ive been driving the car alot. My hollands auto has been holding up great. Its nearing race season again. With race wars being the first event of the year, Im going to be fixing some bits and upgrading some others. Its finally getting a new head gasket with head studs and cams. I picked up some hks 272/264 cams a set of evo 8 valve springs. Upgrading my pte 1000s to ford 1600's and replace both of my dead wideband controllers with a plx m300. Also nitrous :) supension and some other bits and bobs. Ill post up some pictures when i start work.
PostPosted: Tue Feb 16, 2016 12:48 am
Love this car. Hope to be at Race Wars, if so I'd love to check it out.
PostPosted: Tue Feb 16, 2016 12:56 am
I was there last august with Trevor, Glenn, and Eric. Eric has the blue 2g and black dodge race truck. This year ill have my car out if it kills me.
PostPosted: Tue Feb 16, 2016 9:51 am
Lookin good. Rematch? :yawinkle:
PostPosted: Tue Feb 16, 2016 3:44 pm
no easy way to say this but that BOV placement is in a terrible spot. air doesnt make turns well when at high velocity. there going to be a tremendous amount of turbulence at that turn. the air is essentially running straight into a wall.
years ago I made a twin intercooler setup for my 89 mirage turbo. the y piping feeding the two coolers was similar to what you have here. where cooler one was fed by pipe heading to TB. cooler two fed by pipe heading to BOV. when a did a pull and felt intercoolers intercooler two was hot to the touch. while cooler one was cool. clearly all the air just went straight. I even tried to correct problem by adding a divider inside pipes that directed 30% to hot cooler and 70% to cool intercooler. didnt work. the hot intercooler was still doing 80% of the work. amazed me at the time. but learned something very important. air has mass and acts more like a stream of water. treat it like that. make sure water doesnt splash anywhere inside your pipes.
PostPosted: Sun Feb 28, 2016 1:21 am
I've never had any issues with boost control.
I picked up a spare engine yesterday. It even came with a couple goodies. I now have a vemon 1g intake manifold and a boomba 75mm tb. Pulled the oil pan off and found a couple bits large pieces of a journal bearing in the pan was well and some smaller parts on the oil pick up screen. :(
PostPosted: Fri Mar 04, 2016 1:09 am
Tomorrow im picking up a plx wideband and a set of ford 1600's. Ill prolly be picking up another set of evo 8 valve springs/retainers, the ones a picked up didnt have retainers. Ripped apart the 6 bolt i got. Its junk. Head is still good. head surface still looks good and fairly fresh. So its going to get bolt on the my bottom end with another mls. I need to install valve spring and hks cams into that head.
PostPosted: Sat Mar 26, 2016 2:41 am
ripped car apart and put it back together.
https://www.youtube.com/watch?v=14ntxM8dtQM
PostPosted: Thu Apr 21, 2016 9:59 pm
PostPosted: Fri Apr 22, 2016 8:41 am
The guy in the red flat bill hat likes your car so much that...
And where are my wheels? The OZs would look soo much better on slicks!
PostPosted: Sat Apr 23, 2016 3:12 am
that he does. The hoosiers came mounted on those. The ozs are setting next to a pair of Hancock ventus v214s
PostPosted: Wed Jul 06, 2016 2:35 am
that the race i won? lol
08 silverado max
91 Eagle Summit 4g63t swapped
