It is currently Sat Jun 15, 2024 6:07 pm
PostPosted: Fri Feb 12, 2016 10:47 am
Hey guys, I'm still trying to piece together a stock shock and strut combo on the Colt but I'm missing some pretty important parts.
Front: The top plate(not the top hat) that holds the spring down. It's sits between the spring and the top hat. I need both sides.
Rear: Top mounts. Both sides. I can't find them anywhere so if you have a set lying around I'll take them.
Cheers,
Steven
1991 Plymouth Colt - Project
PostPosted: Tue Mar 01, 2016 9:20 pm
Hey man you still need the spring caps? I can snatch up a set from a parts yard near me... these for a 3g csm hatch?
Abe
PostPosted: Thu Mar 03, 2016 3:21 pm
Yeah they're for a 3g hatch. You know which one's I'm talking about right? I still need them.
PostPosted: Sun Mar 06, 2016 5:24 am
Yes I think I know what you mean, you mean the black round plates [with keyed center hole for the strut shaft] they sit on the upper side of the springs.
Id what you need in the image in the link below: I think you mean item #5 or seat spring upper correct?
http://www.factorychryslerparts.com/sho ... gory=20317
If that is correct I currently have 2 of item #5, will post up pictures upon request.
and if you need the rears mounts, I can source those as well just Id them in the image...see link below
Abe
PostPosted: Mon Mar 07, 2016 1:28 pm
Will 4g parts work? I have 2 old 4g complete shocks w springs
94 Mitsubishi Mirage "4dr"
PostPosted: Mon Mar 07, 2016 8:35 pm
If you want some factory turbo front hubs/spindles/brakes, let me know. I have a complete set.
PostPosted: Wed Mar 09, 2016 12:37 pm
Tony I'll probably take them off your hands once I'm back from deployment in May. Do you have any of the rear disk brake stuff?
Mitsubishikid- Yeah that's it! I need two(one for each side)
PostPosted: Wed Mar 09, 2016 8:38 pm
No rear disk stuff.
PostPosted: Sun Mar 27, 2016 7:05 am
Bump! mitsubishikid I sent you a pm! I still need to two caps you grabbed from the yard.
PostPosted: Sun May 15, 2016 2:49 pm
caps were shipped out last Wednesday, and should have arrived last Friday, I hope you get the csm back on the road man.
Abe
