It is currently Sat Apr 27, 2024 9:06 pm
PostPosted: Mon Oct 29, 2012 11:16 pm
I only read the first few posts here, so sorry if this has been asked already.
I will be doing a 4g63 dune buggy project. Do you do custom mounts to specification?
Kyle
Atlanta, GA
404-514-1344
Current project - 4G63 street legal rail.
PostPosted: Tue Oct 30, 2012 6:27 pm
Are you still offering the 4x100 rear disk kit?
PostPosted: Wed Oct 31, 2012 8:44 am
Yes I am
PostPosted: Mon Mar 18, 2013 12:32 am
Are you still making mounts and harness?
PostPosted: Tue Mar 19, 2013 9:07 am
Yep
PostPosted: Sun Jun 16, 2013 9:21 pm
PM sent
PostPosted: Sat May 17, 2014 8:09 am
Are you still making the 4g mirage mounts to run the 1g trans. Also will the adapter harness work on the 4g mirage? Thanks for your time.
PostPosted: Sat May 17, 2014 10:11 pm
I do make an adapter harness for a 4g Mirage but I never bothered to make jigs for the engine mounts.
PostPosted: Mon Sep 29, 2014 1:09 pm
do you make the dash harness adapters for a 92 expo using a 1g harness? i have already got the 2 plugs that go to the dash of the expo, just need a jumper made , can get 1g dash side plugs also.
PostPosted: Tue Mar 01, 2016 11:29 pm
I am interested in the rear brake bracket. How much to ship to Canada, postal code m9c1v3?
DRCOLT
1989 3g Colt GT turbo w/4g63t
PostPosted: Wed Mar 02, 2016 9:29 am
$25 for a small flat rate box to Canada
PostPosted: Mon Oct 24, 2016 9:21 pm
I forgot about this post, I havent received the notifications.
I am still looking to convert my 88 sedan colt from drums to disc.
Can I get the measurements on the adapter from hole to holes? I was going to order 1995 Hyundai Elantra GLS 1.8 w/abs parts, but the bracket adapter is discontinued.
If your parts measure up to my car. I will take a set of adapter brackets.
DRCOLT
PostPosted: Tue Oct 25, 2016 3:35 pm
From center to center on the two top holes it's 3-1/16"
From center to center on the two side holes it's 1-3/4"
From center to center diagonal it's 3-1/2"
All measurements are approximate but very close. Hope this helps...
PostPosted: Tue Feb 14, 2017 8:08 am
Hi there, you don't by chance make a trans mount to swap in a 2G AWD transmission, if so I could definitely use one!
Cory O.
'89 Mirage Turbo
'89 Skyline GT-R
'93 300ZX
PostPosted: Thu Feb 16, 2017 7:50 am
The mounts that I modify should fit the 2g trans as well. The upper stepped part of the case is the same.
