It is currently Thu Apr 25, 2024 4:27 am
PostPosted: Fri Aug 28, 2015 6:56 am
The 94/95 galant ran a 4g64 in the same configuration, so the ECU may be compatible.
PostPosted: Sat Aug 29, 2015 1:28 am
Cool thanks, going to a few junkyard s tomorrow. Fingers crossed!
PostPosted: Sat Aug 29, 2015 5:43 am
The damaged component on your ECU is a capacitor labelled C6 on the board.
Capacitor is C, Resistor is R, diodes is D, Integrated Circuits is IC ...
In this location (one connection to ECU ground) it will be used for decoupling/filtering an high or low frequency signal (EMI) capacitor value depend, from the ECU components.
Hope it help a litle.
PostPosted: Sat Aug 29, 2015 12:07 pm
That thing that is half off the board is a ceramic capacitor, hence "C"6. They are a standard value, should be .1uf 50V
PostPosted: Sun Feb 07, 2016 9:17 pm
Still having the same issue.
The weather has been great for February, I've been back at it after not touching the car for months.
Recap: repaired ECU thanks to everyone's advice, ran great for a few days then came back. Seems to run fine on the freeway, don't know how that effects anything.
Idles ok when cold then starts to surge after warm. After about 20 minutes it'll die if just left sitting.
When I do give it throttle I get huge smoke clouds. Kind of smells rich to me but I have no diagnosing experience. It's darker smoke.
While driving around the neighborhood testing it I've gotten some absolutely radical backfires. Like earth shattering call 911 backfires.
This happens when I'm giving it throttle but it's cutting out and usually dies. Doesn't seem to happen at freeway cruising rpm speed, just around town.
No CEL when reading with a code reader. I've replaced:
Fuel pump
Checked cat it's not clogged
Fuel filter
Plugs
Wires
Tried another ECU besides my repaired original
Cleaned throttle body and sensors
What should I start poking next? Thanks!
PostPosted: Mon Feb 08, 2016 7:52 am
Have you checked all your hoses and gaskets for vacuum leaks? You can spray brake clean on them while it is running to see if the idle changes any, that would be the leak.
PostPosted: Mon Feb 08, 2016 12:53 pm
Try ohm'ing out the Throttle Position Sensor and make sure it does not have any "flat spots" of bad or non-gradual change in continuity as the throttle shaft is rotated.
Only two wires/pins will give you this reading.
Here is the page I came to years ago.
http://www.plymouthlaser.com/tps.htm
PostPosted: Tue Feb 09, 2016 2:39 am
Thanks guys! I've examined the intake and vacuum lines but not sprayed them, I'll try that.
I have an ohm meter but never really used it, I'll study up and get a buddy who is more mechanical than I am to help.
Hopefully this gets it running smooth, I'm looking forward to some fun mods.
PostPosted: Mon Feb 15, 2016 6:45 pm
Ok I had some free time today.
When trying to turn it over (normally cranks right up) it would not turn over, and then made the weirdest sound, almost like the whole car was vibrating and kind of like dieseling. Really hard to explain. I tried to record it didn't do it again. After the normal 20 minutes of idling or so it got rough and surged somewhat. I noticed today though that if I turn the A/C on it went from idling at 1200 rough/sputter down to about 800 and smooth. I do not know if the A/C draws more amps than other accessories but this didn't seem to work when I turned everything else on (lights, heat, radio).
-No change when spraying brake cleaner and carb cleaner around gaskets/vacuum.
-I will pull the TPS off after dinner and test my skills on that.
BUT there is actually good news.
FSM came in the mail. I have some good reading material now.
And the end all be all is that my wife said she would be willing to drive it (this is completely opposite of normal). So that totally changes the approach to the car, it's not an "extra money pit" but a means of transportation now. Good things are happening, I can smell it.
PostPosted: Mon Dec 05, 2016 3:04 am
Wow! I am back from the dead, or the Eagle is at least. Can't believe I haven't posted since Feb on this. I am crazy about this car, and while a lot has changed I am not letting this one go. It is too unique. I got it running ok but never really figured out the idling issue. CV joint or rear diff issue popped up and I parked it. :toimonster:
Great deal popped up and a 95 Talon GSX and so I towed it home and started 4G63T swap
Been parked for years, I think a cat was living on the A/C compressor. There is hair everywhere.
PostPosted: Mon Dec 05, 2016 3:06 am
Wow those pics seem too big. They took way too long to upload and edit in photobucket.
I feel behind the times, what is everyone using to upload pics? Do you do it straight from your phone to Photobucket?
PostPosted: Tue Dec 06, 2016 12:46 pm
Postimage.org is my favorite. Sad to see such a clean 2g be scrapped as a donor.
PostPosted: Thu Dec 08, 2016 11:41 pm
I'll try it out.
Maybe I take good pics? It is not that great. It hadn't been registered since 2009 I think. A few people are interested in the shell so it may live on?
PostPosted: Sun Dec 11, 2016 12:37 am
Great progress man keep up the good work, and yeah definitely let that shell live to race another day they are pretty rare these days.
Abe
PostPosted: Sun Dec 11, 2016 3:49 am
I have tons of parts coming in the mail, very excited. Haven't done a full tune up on a car in a really long time.\
Gaskets, timing belt+water pump and supporting maintenance, BSE kit, FSM for both cars, clutch, and a bunch of smaller fun items.
I find it funny we are concerned about the well-being of the donor 2G. I have never looked twice at an Eclipse as a car I'd want to own. The AWD Eagle is infinitely more rare than the DSM. I have tons of interest in the shell, and hopefully just trade it to a good home for some parts for the Eagle.
Users browsing this forum: No registered users and 67 guests
