It is currently Tue Apr 23, 2024 9:05 am
PostPosted: Wed Jan 27, 2016 4:01 pm
Hey guys, i'm new here recently referred to 4g61t by 89MirageMan.
I currently own a 2000 Mirage LS coupe which imm slowly turning into a 4g64dohc power Asti rep and my 1997 Mirage DE sedan which i'll be converting to an Evo V replica with a turbo 4g64 dohc also.
I'll be on the look out for an Expo soon for my delivery vehicle for my small company i made a couple years ago called TechNation.
I'm a retailer over at mirageforums.net and hope to be able to bring parts for you guys here at 4g61t soon since csm's are getting a bit harder to find
Founder of TechNation Aug. 2014- Present
PostPosted: Fri Jan 29, 2016 10:26 pm
Not sure how I missed this but welcome. This guy is a fellow junkyard junkie. He actually came across a 3g summit hatch a little while ago and I asked him to join here. These cars are getting so scarce and we need the parts before they get crushed. If you can think of anything you need shoot him a pm.
PostPosted: Sat Jan 30, 2016 12:14 am
Thanks Chris!
I'll be going to the yard tomorrow to pull the plugs off the summit and the talon for you.
Got a few things to pull tomorrow so it should be a good day
Photobucket is currently down so i can't post pics but i'll post some pics of the hatch once it's back up
PostPosted: Sat Jan 30, 2016 4:36 am
Welcome.
:partyman:
1989 Mirage Turbo (Daily).
'89 DODGE COLT GT TURBO.
1994 DIAMANTE - SOLD
PostPosted: Sat Jan 30, 2016 9:33 am
is there a dohc head that fits the 1.8 engines? though you might know
PostPosted: Sun Jan 31, 2016 1:22 am
Thanks mirage760!
Lancerman, the heads that fit the 4g93 are the 4g92 mivec dohc head, the dohc 4g93 head and the dohc 4g94 head
PostPosted: Sun Jan 31, 2016 11:06 am
Bender, you can't just put a DOHC head on the SOHC 1.8 block though right?
PostPosted: Sun Jan 31, 2016 11:28 am
HI, and welcome.
Please let me know if you run across a valve cover with the -1600- casting on it.
Thanks
Mandy
PostPosted: Sun Jan 31, 2016 12:15 pm
Chris, on the 5G you can although i wouldn't advise using a 2.0 head on a 1.8 block
Arrowhead, i'll get to you as soon as i spot one
PostPosted: Sun Jan 31, 2016 6:27 pm
Welcome, I am also in central florida!
94 Mitsubishi Mirage "4dr"
PostPosted: Mon Feb 01, 2016 9:30 am
I'm speaking about the 4G93 from the 5g Mirage and the expo wagons, not the 1.8 from the early elantra's. What engine are you talking about?
PostPosted: Mon Feb 01, 2016 12:59 pm
Thanks for the welcome sunchaser!
Chris, 5g 4g93 is what i meant.
You can swap in a 4g92 dohc head or one from the 4g93t dohc cm5a lancer gsr
I havent read much into that swap since i'm planning on using a 64 with a kia head.
Just gotta get a matching head gasket. Not sure if the dohc one changes from the sohc.
I believe michael cadwell from mpf has a 4g93t head on his sohc 93 block
3g hatch and 1g dsm parts
PostPosted: Mon Feb 01, 2016 4:48 pm
Awesome, had no idea. I will admit that I know very little about the engine from the 5g mirage. Too bad Hyundai never made an equivalent engine to steal the DOHC head from.
PostPosted: Mon Feb 01, 2016 6:05 pm
Didnt Hyundai make a 1.6 dohc?
If they did, it's most likely based off of the 4g92 or 4g18.
If it's based off the 92, then we're in luck for a us side dohc swap
PostPosted: Mon Feb 01, 2016 7:10 pm
I've been intrigued with the growing number of mitsubishi v6 swaps in the 5th gen Mirages, from what I gather there really isn't much to it.
