It is currently Sun Apr 28, 2024 9:00 am
PostPosted: Sun Oct 11, 2015 7:54 pm
Good day today........didn't break!!!!!!!!!!!!!!!!!!!!!!!!!!
Took off the snow tires and went up on the stockers, 195/15's street tires. some no-name tires I bought to roll the car around the shop a few years back. Here is a picture with the Summit on the trailer
1st run it wheel hopped hard all through 1st gear and when I hit full boost in 2nd ( around 3200rpm) it wheel hopped to the rev limiter. Ran good in 3rd and 4th and ended up with a 11.994 @123.71 with a 1.908 60' time which is my 1st 11 second run.
2nd run was bad, 1st to 4th, back to 2nd then 3rd.............bad.
I was running brackets and had to dial in so I just wrote 12.0 and hoped for the best.
Pulled up next to a 2011 Evo dialed in at 12.70 and.................................................................................................................................................................................................................................Awesome run, knew I was going to break out but it was worth it.
PostPosted: Mon Oct 12, 2015 1:02 pm
Very nice, what turbo are u running?
PostPosted: Mon Oct 12, 2015 2:30 pm
Very nice. Mod list?
PostPosted: Tue Oct 13, 2015 6:28 am
I started this build 8-9 years ago so the list of parts is dated.
Turbonetics t3/t4 ceramic ball bearing .62
AEM ecm
HKS 292's
1000cc's
PTT clutch
I am still on my break in tune, safe timing and the 20LB WG spring, no regulator yet.
And crappy 195/15 cheapo tires I bought just to push the car around on for the last 6 years. My tuner want to up the boost to 35-40 next year.
BTW the tunes name is Raif and he ran his car on Sunday also and went 8.9@160, what a run!!!
Mark
PostPosted: Tue Oct 13, 2015 5:26 pm
FWD?
PostPosted: Tue Oct 13, 2015 6:54 pm
FWD?
Sorry, I thought most of you had seen the build at one time or another, I started in 2006. Here is a link to the build
http://www.4g61t.org/forum/viewtopic.php?f=64&t=31998
I put way too much time into detail, I wanted the Summit to look totally stock inside and out. I put everything back in, full interior, everything. It's pretty heavy, I weighed it at Epping and it was a few pounds shy of 3,000 LBS with my 215LB ass in it. I was thinking it weighed closer to 2500ish LBS.
Mark
PostPosted: Tue Oct 27, 2015 10:10 pm
Nice times! And clean car.
