1989 Dodge Colt GT
VIN: JP3CU54Z8KU075029
Chassis Mileage: 14x,xxx
Engine Mileage: ~5-10k
The car is located in San Diego, CA.
I’ve had this car for almost 10 years, it’s the original M&S Recycling AWD Colt GT. One of (if not) the first AWD conversions on the CSM.
It’s a fully optioned Colt GT – power windows and mirrors, paint is original and faded in places – it is going on 30 years. Full interior. No AC, no power steering.
It made 480whp with the manual transmission and no nitrous.
Runs mid to high 6s at 107 in the 1/8th mile all day in 90 degree heat, hot lapping – on street tires – before slicks.
It is the definition of a sleeper, quiet and unassuming until the hammer is dropped. The exhaust cut-out keeps it near-stock quiet until it’s opened.
All the issues have been sorted out, I haven’t had to fix anything on it in several years.
Engine: (complete tear-down)
Blue printed block
JE pistons match to block (9:1)
Crower rods
Total seal rings
ARP hardware throughout
New bearings
New oil pump
Balance shaft eliminated
Moroso 7-quart oil pan
Ported head
Crower springs and titanium retainers
Stainless steel valves
HKS 272s
O-ringed
3g lifters
New seals
OEM MLS
OEM gaskets all around
OEM timing belt and timing components
Water pump
Active crank dampener
Genuine Mitsubishi alternator
EMS/Electronics
Megsquirt MS2
DIS-2 ignition box
Zeitronix Wideband
PC 680 battery mounted under trunk
Fuel
AN-10/8 feed/return stainless steel lines
Bosch 044
1000cc RCs
Adjustable FPR
10 Gal sump’d cell
Turbo and Exhaust
FP 3065 @ 28psi via manual boost controller
FP 3” down turn
Tial wastegate
Ported 2G Exhaust manifold
3" turbo back, no cats, no muffler (cutout open)
Stock 1G GSX muffler (cutout closed)
Intake/Intercooler
Bar and plate FMIC, 12 x 24 x 3”
2.5” in, 3” out
Tial BOV
Cooling
New radiator, hoses
Spal fan
1G air to oil cooler
Drivetrain
Low mileage 1G W4A33 AWD Automatic Trans
TCU programmed by Dave Katz (no lame buttons to push, just the gas, shifts when it’s supposed to…)
Translab shift kit
New filter and pan gasket
New high-friction 4th gear clutches
Massive trans cooler with fan
Kiggly flex plate
Sinister Speed 9” high stall tq converter
Vacuum pump (for stalling)
Shortened, balanced, 1G driveshaft
4-bolt LSD rearend
Nitrous
100 shot 4-fogger wet Zex system
10lb bottle
Bottle heater w/ gym bag
Wheels, Tires, Suspension
15 x 7.5 Rota Slipstream
M/T 8” slicks, tracked once
GR2 shocks all around
Interior
Full interior
New upholstery front/rear seats
Some dash cracks, carpet discoloring
Exterior
Original paint and emblems
Also included with sale:
Rallyguy’s Willwood caliper adapter kit (1 of 10 made)
Stock Colt GT wheels and center caps
Spare auto 1G AWD transfer case
Stainless steel brake lines
Superpro suspension bushings
The bad:
The starter won’t crank at times, always starts with a re-turn or two of the ignition key
Runs rough when cold, clears up in less than a minute
It’s an old car and has not been restored
Original Conversion Pics:
![Image](https://www.dropbox.com/s/bxnlxsw1nxbjr8q/M%26S%20Build2.png?raw=1)
