It is currently Sat Apr 27, 2024 5:05 am
PostPosted: Mon Sep 07, 2015 8:06 am
Can somebody take a pic of their hatch release setup at the back of the car? I'm guessing a cable runs to the bottom and somehow trips that tiny pin on the assembly up on the hatch. I'm trying to rig up a cable setup that I pulled from a 4g LS car, hoping they are similar even though the 4g has an actual trunk and not a hatch.
PostPosted: Mon Sep 07, 2015 12:06 pm
ur 4g doesnt have a cable trunk lock? I can take pics later of my 4g and 3g if u want both..
PostPosted: Mon Sep 07, 2015 3:12 pm
Just a minute here, I will post some up for you....
Good stuff - trucks bring it!
PostPosted: Mon Sep 07, 2015 3:28 pm
The last two are no help.
PostPosted: Mon Sep 07, 2015 9:05 pm
That's exactly what I needed to see, thanks! That you in the tree? :lol:
PostPosted: Mon Sep 07, 2015 9:44 pm
You betcha, buddy! Yes, that's me up there.
PostPosted: Tue Sep 15, 2015 1:39 pm
New request, does anybody have a pic of the small metal tab that goes in the gas door? It makes the door pop open when you pull the lever. Mine never had this or it came off. The one on my 4g is different. I'm hoping this piece is still on the one hatch left at the yard but if not I'm hoping it came on other Mitsu's as well.
PostPosted: Tue Sep 15, 2015 3:01 pm
hey chris does the 4g latch match the same as the 3g. io was thinking the galant are the same as the 3g .the pull levers look to be the same shape.
PostPosted: Tue Sep 15, 2015 4:03 pm
The 4g levers are identical except for one tab on the top. The 4g one bolts on with two bolts, the 3g just uses one. I cut it off with my cutoff wheel and it worked perfect. I used the 3g cables and the hatch piece though, Natedog happened to have a complete setup laying around but the levers were bad.
PostPosted: Tue Sep 15, 2015 4:38 pm
Odd, I think the part you are looking for is on the lock mechanism. I'll dig mine up and get a picture...
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Tue Sep 15, 2015 4:40 pm
I may still have the complete cable assembly that was pulled out of a car years ago; if your interested?
PostPosted: Tue Sep 15, 2015 5:51 pm
This part actually snaps onto the fuel door. It's really not part of the levers and cables. It's basically a bent piece of metal and it snaps onto the inside of the fuel door. When you pull the lever and it releases the fuel door this piece helps the door to spring open.
PostPosted: Tue Sep 15, 2015 6:12 pm
PostPosted: Tue Sep 15, 2015 7:03 pm
^ nope, its actually a little piece of metal that works as a spring, its where the fuel door bolts to the chassis. I emailed him some pictures earlier of it.
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Tue Sep 15, 2015 7:09 pm
Oh. fail. I was trying to get rid of that piece :)
