It is currently Thu May 23, 2024 2:33 am
PostPosted: Thu Jun 11, 2015 7:09 am
1st time for the Summit and I have not drag raced in 10 years. Summit held up well and I made 7 passes. The snow tires would spin when I hit full boost in 1st gear. The RPM's would spike to 9,500 and the transmission would lock me out of 2nd gear. I short shifted it a few times and got 2nd gear but I need to learn how to launch this thing better.
Run 1
60'-2.388
1320-13.062@118.
Run 2
60'-2.069
1320-12.94@116.56
Run 3
60'-2.085
1320-12.66@119.15
Run 4
60'-2.462
1320-12.976@120.20
Run 5
60'-2.044
1320-12.56@119
Run 6
60'-2.385
1320-12.461@120.57
Run 7
60'-2.118
1320-12.33@120.29
I did the water box the 1st 2 runs and did the burnout- sort of. More like launched it hard. All the other runs I did a dry launch/burnout.
I am running on the base tune still @ 21PSI and 8 degrees of timing.
All in all I had a fun night and did not break anything.
Mark
PostPosted: Thu Jun 11, 2015 8:36 am
Sounds like 11's are well within reach for sure. I'd be pleased with those times, especially for its first time out. Great job!
PostPosted: Thu Jun 11, 2015 9:45 am
Nice trap speeds! That's a Mid-11 car for sure, if you can get the 60-foots down.
PostPosted: Thu Jun 11, 2015 10:12 am
PostPosted: Thu Jun 11, 2015 3:48 pm
You definitely have more in the tune and driving. I'd imagine low 11s are possible. Any video!?
PostPosted: Fri Jun 12, 2015 8:10 am
1st run, I let off because I thought it broke when the tires spun. I the hit it again and assumed all was well.
PostPosted: Fri Jun 12, 2015 6:28 pm
VERY fast Evo in the right lane, me in the left. Evo was told to go home after this run.
https://www.youtube.com/watch?v=m8QGBE1MEoU
