It is currently Sat Apr 27, 2024 8:28 am
 Post subject: ecu and igniter
PostPosted: Thu Jun 11, 2015 7:54 pm
Hello, hello, I have a question, the ecu 4g61t 1.6L uses a small igniter 5 wire while 4g63t ecu uses a larger igniter 6 lines , why the difference? Will this interfere if ecu exchange difference ?
 Post subject: Re: ecu and igniter
PostPosted: Thu Jun 11, 2015 10:04 pm
The 90 dsm's used the 5 wire PTU as well. It's because the coil is different between the two.
PostPosted: Fri Jun 12, 2015 10:24 am
ok, thank you, you can exchange ECU from
CSM 4g61 and DSM 4g63?
PostPosted: Fri Jun 12, 2015 1:37 pm
A 90 turbo dsm ecu will work if you swap out the maf and injectors. 91-94 would require the same mods as putting a 90 ecu in a 91-94 dsm.
