It is currently Tue May 07, 2024 2:37 pm
Post new topic  Reply to topic  [ 57 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Sun Feb 01, 2015 6:20 pm
Engine and transmission are out. Looks bad for the engine. Probably going to need a lot of work. I'll be opening it up this week to see. In the mean time I bought these from my friends wife. He had them done years ago for this car, and they sat in the top of his garage (hence the dusty pictures) they cleaned up nicely, and will be installed when the car is running and I verify the AC system works. IIRC they are Katzkin.
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun Feb 01, 2015 7:11 pm
Those seats look really nice.
PostPosted: Sun Feb 01, 2015 9:07 pm
This is usually a bad sign... :(
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Mon Feb 02, 2015 12:03 am
Wow, so much metal flakes it made it up there! Holy crap, time for a build.
PostPosted: Sat Feb 14, 2015 5:23 pm
Cleaned up the transmission today.
I have the head in the machine shop, and im starting to source parts for the bottom end...
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Fri Feb 20, 2015 7:45 am
The timing job could have been done proper and the oil pump locked causing the timing to jump.....I would tear into the motor.....not telling you anything you have not thought about....like the turbo might be dry from years of sitting which will cause lost of shaft play. I am with Aaron...I would keep the car completely stock.
92 Colt GT 4G63t
92 Summit TSI AWD 4G63t Auto
5 X 90 Talon TSI
90 GSX
PostPosted: Fri Feb 20, 2015 9:27 am
The balance shaft bearing walked causing all the damage. I jus got the head back from the shop this week. I disassembled the short block and now am gathering a parts list. Plan is to put back arp main bolts, and such. Maybe 2g or Evo pistons, since it has to be bored to clean up the cylinders. I'm going to do a 14b, and maybe a 2g exhaust manifold. It will all be stock appearing at least. No plans to upgrade exhaust or anything along those lines. Just get her back running with a good solid engine, one that can take abuse if I end up modding it later on.
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun Mar 22, 2015 5:36 pm
Short block is in the machine shop now... Waiting game I guess.
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed Jun 03, 2015 8:06 pm
I've been working on the interior in my waiting time...
Hope you can see the difference there!
No more fade!
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed Jun 03, 2015 9:13 pm
Those panels look sooooooooooo good!
PostPosted: Wed Jun 03, 2015 10:49 pm
Danggg!
PostPosted: Sun Jun 07, 2015 11:56 am
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun Jun 07, 2015 12:33 pm
love clean cars. this car qualifies.
PostPosted: Sat Jun 13, 2015 2:33 pm
Thanks, I used the SEM bumper coat from your thread, worked out well.
So last couple weeks have been interesting. Abridged version...
Thursday: Bad Crank
Friday morning: deliver good crank
Friday evening: Wrong pistons
Saturday: deliver Stroker crank to match pistons....
Thats right she's going 2.3, with a 14b! My friend always wanted to do it, and since I had gotten his stroker pistions (not realizing they were) I'm in a time crunch for the road rally, I went ahead and ran with it.
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sat Jun 13, 2015 3:14 pm
Very impressive, Nate!
