It is currently Mon Jun 03, 2024 10:34 pm
Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3
PostPosted: Tue Jan 20, 2015 12:22 pm
No Napa stores up there? They have metric taps. Plus 10mm 1.25 is a pretty common size as well.
PostPosted: Mon Feb 09, 2015 8:53 pm
OP, how did the lift go?
PostPosted: Wed Feb 25, 2015 3:45 pm
So there are the spacers we made! Hoping to cram them in tonight....hopefully they go in easily. Being only 2 inches tall I should in theory be able to just unbolt up top and stand on the control arm to pull them down far enough.
Any suggestions or thoughts?
Fixed the link on the pic ... hope you don't mind, Ninja edit.
Looks like one pic.
Flying Eagle
^^^ thank you sir! ^^^
Last edited by AWDColtVista-1992 on Thu Mar 12, 2015 7:48 pm, edited 1 time in total.
PostPosted: Thu Feb 26, 2015 12:17 am
Just make sure the outer and inner axle cups don't bind when at full lock, up and down and side to side while fully down.
PostPosted: Thu Feb 26, 2015 6:29 pm
Mission abandoned last night sadly. I just couldn't get enough space to thread them on to the top hats! Plus it was utterly freezing and I'm a panzy! Will try again this weekend and hopefully have some pics for you all...
Thanks Flying Eagle for the ninja edit!!
PostPosted: Thu Feb 26, 2015 6:31 pm
I really hope they don't cause any issues. Being only 2 inches I bet the springs have sagged more than that! If not I can always face a 1/4" off each side...
PostPosted: Sun Mar 01, 2015 8:43 am
I ended up exploding a CV joint in my lifted laser this weekend. Seems the lift pushes the axle into the trans a bit, so at full lock and high rpm's the CV joint says no more! Just be careful not to over do the lift, or at least don't do doughnuts in the snow :)
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Thu Mar 12, 2015 7:33 pm
Well I finally got the lift in and Moe sits almost perfectly level now! Front end may be slightly higher but I won't know until daylight and it's on flat ground. No noise or binding at full lock. Pics to come tomorrow!! Thank you to everyone who chimed in to help and to this forum for the idea.
P.s. still no 4th gear. ...
PostPosted: Sat Mar 14, 2015 8:56 am
2 inches higher in front!
I can't wait to put the rear adjustable spring perches in to even it out now! Then on to the roof rack and bumpers...
