It is currently Thu Apr 18, 2024 9:05 pm
Post new topic  Reply to topic  [ 57 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Sat Jan 31, 2015 5:42 pm
I run 225/50 tires on 16x7 wheels with +40 offset. My car is slammed in coil overs and the wheels are tucked in the fender still. However I did have to remove the front inner fender liners and roll the fender lip. It's a tight fit when lowered.
PostPosted: Sun Feb 01, 2015 11:25 am
^^^ Can you go lock to lock without hitting the inner frame area? I've contacted the inner frame with 196 65 14, on stock turbo turbine rims.
I try to stay off lock to lock anyways, just as a general rule of palm.
PostPosted: Sun Feb 01, 2015 10:30 pm
Only very very slightly. Only enough to brush the dirt off in one spot. Not a big deal if you ask me.
PostPosted: Mon Feb 02, 2015 1:12 am
i run 225 45 16 +20 xxr 521 on koni struts hypertech springs and coilover sleeves . this pic is be for i got a aliment and my camber plates are maxed out but now it is .2 degrees if i remember right.
08 silverado max
91 Eagle Summit 4g63t swapped
PostPosted: Wed Feb 11, 2015 7:21 am
this is the only wheel avail. im looking for. 15x6.5 wheel what offset is better +35 or +42?
PostPosted: Wed Feb 11, 2015 10:30 am
PostPosted: Wed Feb 11, 2015 10:41 am
×42
PostPosted: Wed Feb 11, 2015 1:26 pm
What bolt pattern and rim width do you run? 16x7 +20?
92 Colt GT 4G63t
92 Summit TSI AWD 4G63t Auto
5 X 90 Talon TSI
90 GSX
PostPosted: Wed Feb 11, 2015 10:01 pm
It's 16x8.
PostPosted: Sat Feb 14, 2015 7:55 am
it is 4x114 16x8 +20 with a 225 45 tire
08 silverado max
PostPosted: Mon Feb 16, 2015 8:33 am
^this is what I am going to try on the Red Summit.....need something in gold
92 Colt GT 4G63t
5 X 90 Talon TSI
90 GSX
PostPosted: Mon Aug 17, 2015 11:09 am
So I'm almost complete with my 4wheel 5lug conversion,rear disc and 94 front big brake conversion on my 92colt hatch. Next in line is wheel setup. What minimum size rim/offset would I need to run to clear the dual piston calipers in the the front?
PostPosted: Mon Aug 17, 2015 12:22 pm
I run 15x7 +34 and it clears by a cunt hair. 16" will clear for sure.
PostPosted: Mon Aug 17, 2015 1:34 pm
Your also running the 94 eclipse dual piston calipers?
PostPosted: Mon Aug 17, 2015 3:42 pm
GVR4 but the same yes.
