It is currently Wed May 01, 2024 5:25 pm
 Post subject: Trans cable help!!
PostPosted: Wed Oct 29, 2014 1:21 pm
Ok guys I have been looking around and I can't seem to find what I am actually looking for, I am running an awd transmission out of a 92 talon in my 89 4g63 swaped mirage. I have the factory turbo mirage shifter cables and shifter base. But I am wondering what bracket I need for on the transmission. I have seen where they talk about useing the factory turbo shift levers but I don't remember haveing to run them on my old colt when I had it 6 or 7 years ago. I just know there are a couple diffrent combinations of brackets out there. But I was wondering if some one could let me in on what one would be the correct one I use. Pictures would be helpful to..
Thanks
 Post subject: Re: Trans cable help!!
PostPosted: Wed Oct 29, 2014 9:38 pm
You need the bracket that bolts to the trans case that holds the cables on, the lever that is bolted on and the one that is welded on. I did a write-up in the archive on how to swap these out. These parts need to come from any 3g csm with a manual trans, turbo or na does not matter.
PostPosted: Thu Oct 30, 2014 11:29 am
Yea I have seen that but I never had to do that on my old setup, was wondering if anyone else is running the awd factory trans levers and not swapping them out?
PostPosted: Thu Oct 30, 2014 2:30 pm
Not that I know of. To my knowledge you have to swap the levers to run the stock csm shifter and cables. Were you using a dsm shifter and cables on your last swap?
PostPosted: Thu Oct 30, 2014 4:34 pm
I don't believe I was, but if I was to run the dsm shifter base and cables do I not need to modify the the shifter arms?
PostPosted: Tue Jan 20, 2015 1:07 pm
I used the CSM setup and just cut the shift arm of the shifter rods on the original transmission. I then removed the ones on the AWD transmission and welded the CSM parts to the AWD shift rods.
Mark
PostPosted: Tue Jan 20, 2015 3:12 pm
Easiest way to do it without cutting and welding. Note you still need the up/down CSM lever that bolts onto the trans though.
http://www.4g61t.org/forum/viewtopic.ph ... it=shifter
just noticed we bumped an old thread.... :partyman:
PostPosted: Tue Jan 20, 2015 3:50 pm
No biggie, I'm sure this info will help someone else who searches in the future. I can't imagine trying to bend that thick shift lever with a pair of visegrips but it looks like it worked out well. It's always nice seeing people doing things differently.
