It is currently Sun Apr 28, 2024 7:45 am
 Post subject: Hello
PostPosted: Mon Jan 12, 2015 7:11 pm
New to the site and trying to learn and get all the info I can
Picked up a 92 Plymouth colt the other day for next to nothing
I already got a 92 turbo DSM harness, jumper harness, and 92 eprom on there way. It has the shifter cable instead of hydraulic master and slave. The car is a 4 speed manual right now. My goals with it is 4g63t swap, keep it fwd, 350-400hp on 93oct
Hoping to get some help, been search a lot and can't really find clear answers
As, converting it to hydraulic clutch, full 5lug and 2piston front with rear rotor conversion.
 Post subject: Re: Hello
PostPosted: Mon Jan 12, 2015 7:25 pm
Welcome! The hydraulic conversion is fairly straight forward with just a minimal amount of cutting involved. There are few builds on here that have some detail into it, the templates are there on all the firewalls regardless of auto/4 speed/5 speed.
Also you better get your current location up before the gestapo comes for you as well. :butthead:
PostPosted: Mon Jan 12, 2015 7:34 pm
Yes, locations are mandatory here.
:supz:
PostPosted: Mon Jan 12, 2015 7:53 pm
Whoops my bad, I am currently in Richardson TX
I also have a Evo ix that was built until I sent a rod through the block lol. So I have 2 projects
I have been searching builds, haven't found to much info on it. Seems that 1.8L master cylinder with slave and lines, but what all years are the same? Also do I need sto swap out my clutch pedal assembly?
PostPosted: Tue Jan 13, 2015 3:14 am
Welcome aboard, feel free to post your project on the Builds section...
PostPosted: Wed Jan 14, 2015 8:19 pm
Thanks! I will, I'm hoping just to find the hard parts. It's a 92 and I need to convert it over to a hydraulic clutch system
