I just pulled the engine from my colt (it was built by someone else so it had the f5m21 trans with the 63t.
I don't know what kind of clutch and flywheel this is. My guess is it's a 2.0 na setup. It's smaller in size than the turbo. The crazy thing is the splines are the same. It slides right on a f5m33 trans. So why the hell wouldn't everybody just use the turbo clutches?
I was POSITIVE I read 100 times before the splines/ size of shafts are different.
I thought you had to use the n/a clutch with the f5m21 because it wont clear a bigger flywheel from the turbo.
