It is currently Wed May 08, 2024 5:43 am
PostPosted: Sat Dec 27, 2014 8:31 pm
Hello i have a mirage 89 awd but i am missing the driveshaft i heard that 2g driveshaft they are 1 in shorther any thoughts? Thanks.
PostPosted: Sat Dec 27, 2014 8:38 pm
if you have a awd colt u need a custom fitted shaft. these cars are shorter than the dsm's
PostPosted: Sat Dec 27, 2014 9:13 pm
I got that , but you can still custom a 2g to make it fit right?
PostPosted: Mon Dec 29, 2014 7:18 am
It may be a little more difficult than that. Your mirage was converted to AWD most likely utilizing a modified 1g driveshaft. The 2g driveshaft has different carrier bearings and possibly mount points. You may also have to modify the body mounts to change to a different driveshaft.
