It is currently Sat Apr 27, 2024 6:53 pm
Post new topic  Reply to topic  [ 160 posts ]  Go to page Previous 17 8 9 10 11 Next
 Post subject: Re: Dodge colt gt 89
PostPosted: Fri Oct 10, 2014 5:40 am
Hey Remy, can you tell me a little more about your radiator? I've been thinking of a custom radiator if I ever put a big turbo on the car. I like the full length core yet shorter height wise so it tucks under the radiator cross support so it can but mounted more forward towards the bumper like yours is. I see that its a dual pass radiator. How many cores and what are the dimensions of it? For a daily driven car I like this much better than a 1/2 radiator or VW radiator. Last question, where did you get it or have it made for you? I'm assuming its a custom job and not "off the shelf". Thanks.
PostPosted: Fri Oct 10, 2014 2:02 pm
@ Shawn: This is the regular radiator upgrade for our Colt's, Afco 80107N
Many informations about it on the forum, use shearch fonction.
You need to soldering a custom bung for water temp sensor like factory, and custom brackets.
An lower arm bar is a great improvment for the LCA effort link to the body with powered little car like our Colt.
So much want ... in those pictures. 8)
Your family must be happy to have you back now Remy! :D
@ Tim: Take your time, everything is possible with ten fingers, good friends for custom parts and free beadblasting.
And five years of budjet of course, not possible for everyone i understand that easily...
My family is tired, i was very nervous these last days.
15/16 hours by day to work on the Colt since August 8)
@ Tonus: Come here with your camera and juge yourself :yawinkle:
@ Chris: Thank you man for your support, i appreciate it !
Week end work is idle fine tune and front body instalation, with sun light i hope for nice pictures.
Remy
PostPosted: Fri Oct 10, 2014 3:38 pm
Pay all my travel expenses, and I'll gladly do it! :yawinkle:
PostPosted: Sat Oct 11, 2014 8:21 am
Well don't I feel stupid. ](*,) I thought the Scirocco radiator was a small 1/2 one. I need to get out more. haha Thanks for straightening me out.
PostPosted: Sat Oct 11, 2014 3:33 pm
No problem :lol:
Day light pics my friends.
Dusty car ...
Idle tune is finished, litle road test today.
No leak, no problems for the moment.
Remy
PostPosted: Sat Oct 11, 2014 3:51 pm
Sweet, sweet victory for you my friend!
God it must have felt like heaven to sit in the car and drive around for the first time under it's own power since you took it all apart for the first time.
:prayer: :prayer: :prayer: :prayer: :prayer: :prayer: :prayer: :prayer: :prayer: :prayer:
P.S.
I found your car on video, well at least in GTi form. Yes, it's German so a C58? versus your C53A.
https://www.youtube.com/watch?v=Qb517PTJ_VA
PostPosted: Sun Oct 12, 2014 3:25 am
Old video for sure ! :D
Feedback from the road test, i dont feel good the de-powered rack for the moment.
The Colt need an professional geometry i know, i'll decide after that if i keep this way or re-instal the power rack system (friendly with my mountains roads, many turns)
It's a pleasure to share my pics and detail about this build, i dont search applause or congratulation.
Only respect, 6 years back i knew nothing about EFI and turbo car.
It's a good way to learn and this forum is my high school
Thanks you Tim for your comments :wink:
PostPosted: Sun Oct 12, 2014 4:46 am
Very interesting setup with the A2W. I am glad everything worked out Remy.
PostPosted: Sun Oct 12, 2014 5:43 am
Thanks you Cody.
I could update latter about the WAIC air temp performance.
But i'm sure about the minimum turbo lag procured with the short piping :wink:
PostPosted: Sun Oct 12, 2014 1:10 pm
Very interested in water to air set up.
Are you using another radiator somewhere?
Very nice build.
PostPosted: Sun Oct 12, 2014 1:24 pm
Yes, very nice car Remy!
I'm kind of undecided on my depower steering mod as well. Its not real bad but at times it does get heavy holding it into a corner. Its certainly tolerable for a daily driver in my opinion but I'm not so sure for road course or track duty. I can see my arms getting tired quickly on a road course or doing a lot of spirited mountain driving.
PostPosted: Mon Oct 13, 2014 1:49 pm
@arrowhead : Thanks, the heat exchanger for the WAIC is mounted like a FMIC, see the pics on this page or back to page 9 for best response
@Shawn : Thanks also, i look already for an electrical pump from a Renault Clio car, french power steering pump are aprouved by many DSM and EVO users. Buschur make big money with this pump :D
I decide latter if i swap or not.
Remy
PostPosted: Sun May 10, 2015 6:45 am
Bad update...
My machine shop has killed my head during the valve guide replacement, confirmed by my insurance expert in february.
Bad method used, cold head and press = metal disaster
Short story:
-The same shop has improved my 4G67 head without any problem in 2011
-After that, i spent maybe 30 hours of porting and polishing
-The same shop has milled , valve guide replacement, 3 angles job (with leaks the firs time) with new SS valves
-After maybe 2 miles of leaks test running at very low speed in 2014 december, a bad sound come from the top of the bloc
-Three valves guides playing up and down in the head
-After fighting with the shop, the expert has decided to refund me the working cost and imposed the shop to find another 4G67 head for replacement
I think use the stock 4G61 head for the moment, tired about this build finally 8)
PostPosted: Sun May 10, 2015 9:50 am
Well, if you don't want to, or cannot find another 4g67 head with larger ports on both sides, maybe consider a 2G intake manifold or a Cyclone dual runner intake manifold that can be port matched with epoxy by lancerman (Jerry). Natedog had an intake done that way.
It will then mimic the exact port dimensions of the 2G head. That or mix in an EVO3 intake manifold because it has the high port velocity also.
Very sorry to hear that the tolerances were messed up with the cylinder head. I've seen all the work it takes to prepare and install a single part on these cars, so for you to have to take the head off again after paint, prep, and new gaskets .... this should not be happening to you of all people. I hope this doesn't take the car off the road for the summer.
PostPosted: Mon Sep 07, 2015 1:50 am
Just a preview my friends :D
Running again, new 4G67 head...
Tuning time
Users browsing this forum: No registered users and 136 guests
