It is currently Tue Jun 04, 2024 8:27 am
Post new topic  Reply to topic  [ 160 posts ]  Go to page Previous 17 8 9 10 11 Next
 Post subject: Re: Dodge colt gt 89
PostPosted: Wed Aug 14, 2013 2:32 pm
Last picture, untouched from two month :-?
I hope find good motivation for this winter with my SO flying trip ...
PostPosted: Fri Sep 26, 2014 6:52 pm
Up !
Seven days for the start up !
Ready ? :D
PostPosted: Sat Sep 27, 2014 5:17 pm
Yup.
PostPosted: Sun Sep 28, 2014 12:23 am
Not sure how I missed this. Very nice. We can never make them look this nice.
1985 Mitsubishi Cordia
Build in progress
PostPosted: Sat Oct 04, 2014 3:54 pm
I need time for posting more pictures sorry, actual work stage :
Starting tomorrow i hope.
PostPosted: Sun Oct 05, 2014 12:55 pm
F#cking bad starter or wiring system :evil:
Update later my friends
PostPosted: Sun Oct 05, 2014 10:20 pm
Oh, you too? :lol:
That happened to me also.
Bench test the starter, if good, move forward.
I found the wiring ground connection just below where the factory battery goes, is a connector that runs back towards the starter. Good for a green/corroded spot.
If you have a signal from the ignition to the top of the starter solenoid, you will confirm a circuit all the way to the starter.
Make sure the starter ground wiring has an "actual" unpainted connection to the starter body, AND the starter plate is contacting an upainted surface of the starter nose, AND an unpainted portion of the block. It doesn't have to be that complicated, but it came that way from the factory, plated, but non-insulating by nature.
Otherwise you only have the power wire coming in, and the single ground wire coming out. More unpainted surfaces = more return to ground via the block and ground straps/wires.
I see a lot of paint, and a damn good job, but it could be insulating the connection.
Hey, aren't you an electrician by trade ?? :supz: I j/k.
PostPosted: Mon Oct 06, 2014 3:33 am
Did you try jumping the starter with a screwdriver to see if it was bad signal wire or bad power wire?
PostPosted: Tue Oct 07, 2014 5:43 pm
Thanks for help.
All the wirring is new and made by me with O gauge for positive from trunk (batterie) and OO gauge for all's grounds.
Starter bench tested is ok, but not installed in car !
Two days lost with this crazy story, controlled again all wirring like suggested by Tim.
Swaped it with another and everything is fonctionnal now :D
Started the Colt tonight.
I need to play with Link for SD base tune before local inspection.
Last pictures tomorrow my friends.
Remy
PostPosted: Thu Oct 09, 2014 2:06 pm
Soldering part, custom water tank for WAIC. 6 litters added with him, total water volume is 8.2 litters in system.
BOSCH water pump install
Afco Cobra heat exchanger
Front passenger wheel, head light washer from a GTI converted to windshield washer, added one pump and modified wirring and hoses
Fuse box mod, two relays (water pump, fog light) and 3 fuses (water pump, fog light and gauges) added
Boost control
Wirring adaptation from the USDM wires to EUDM headlight, one relay by H4/H1 light and new foglight wirring comand.
Still on stock rebuild caliper, ceramic pads and Brembo modified disc SP Performance
Custom front lower bar.
Oil cooler B&M, nightmare to find a good install way.
Spal fan.
Remy
PostPosted: Thu Oct 09, 2014 3:33 pm
Looks great, all these years of hard work and money has paid off for you! I just went back to page 7 and looked at the stock pic of under the hood. What a difference it is now.
PostPosted: Thu Oct 09, 2014 3:50 pm
How in the HELL is everything SO clean?!! Haha
PostPosted: Thu Oct 09, 2014 5:11 pm
he flew chris over there to clean it lol
PostPosted: Thu Oct 09, 2014 5:56 pm
Car looks awesome! Yes, clean is an understatement! I love the control arm bar too. I've been wanting to make one for mine.
PostPosted: Thu Oct 09, 2014 9:45 pm
So much want ... in those pictures. 8)
Your family must be happy to have you back now Remy! :D
