It is currently Thu Apr 25, 2024 5:21 am
Post new topic  Reply to topic  [ 57 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Mon Feb 24, 2014 7:26 pm
I like that! How is the position?
PostPosted: Mon Feb 24, 2014 7:28 pm
Excellent really, should have done this a long time ago.
PostPosted: Mon Feb 24, 2014 10:12 pm
Yeah, with my wheel being flat it sits just a little far away. It would be nicer with a little dish like your wheel. However it's still great.
PostPosted: Thu Feb 27, 2014 9:12 am
^ thought about adding a quick release? it would double as a spacer.
They also make spacers http://nrgsuperstore.com/collections/in ... acer-black
PostPosted: Fri Jul 11, 2014 11:45 am
I have the NRG quick release on mine. Placed the wheel closer to me (which I wanted)
PostPosted: Fri Oct 03, 2014 11:13 am
how can I fit those gt steering wheel on a non-tilt hub? it seems the gt has bigger holes.
PostPosted: Fri Oct 03, 2014 12:18 pm
The colt GT wheel will install into a non-gt car without issue.
PostPosted: Fri Oct 03, 2014 3:06 pm
that's the 3 spoke right that's odd mine wont fit it seem that the gt wheel has bigger holes that connects to the shaft. Mmm... what can I do about this??
Do we have any retrofit from other mitsubsihi model that will work fine in our cars?
PostPosted: Fri Oct 03, 2014 6:43 pm
Where are you located?
PostPosted: Fri Oct 03, 2014 7:11 pm
I do have colt or lancer in the Philippines also. Im here in Marion, Chadwood.
PostPosted: Fri Oct 03, 2014 9:08 pm
your location says Indianapolis so I thought you were here in Indiana in the u.s. It's very possible that you have a smaller diameter steering wheel mounted over there since you also have versions of the vehicle that we never got like 1.2 or 1.3 liter motors
PostPosted: Sat Oct 04, 2014 12:28 am
I just got back in Indiana, I brought a gt wheel when im in the PH and it never fit the holes is way bigger. Are there anything I can do to make it fit I left it there.
PostPosted: Sat Oct 04, 2014 2:02 am
Not sure about that. The turbo mirage wheel I bought won't work with my Colt GT column.
PostPosted: Sat Oct 04, 2014 10:44 am
I see a lot of talk about GT steering wheels, but mainly, the 3 spoke wheel everyone has, was equipped on the TURBO GT model and 1.6NA Summit GS, over here in USDM land. Europe got GTi's which would have this wheel also.
I wonder if the tilt/telescope column is the only reason the steering wheel won't fit onto base model columns that came with the two spoke, base wheel.
I know we've seen posts about the tilt column being different. I haven't gone far enough back into this topic, for a while now, to remember the difference but I think we found it.
PostPosted: Sun Oct 05, 2014 2:02 pm
The tilt column is different and so is it's steering wheel. The column shaft has a different circumference and taper. I added tilt/telescoping to my base sedan and had to swap both the tilting column and the telescoping steering wheel.
Interestingly enough the eagle sedan I got my tilt column from had a 2 spoke telescoping wheel. That car was a 89 1.5L sedan with power window options and A/C. It had the 80's blue interior. I got a 3 spoke telescoping steering wheel from another sedan, an 89 Colt Sedan only found in Canada. That car was rare.
Users browsing this forum: No registered users and 30 guests
