It is currently Tue Apr 30, 2024 11:13 pm
PostPosted: Sun Sep 14, 2014 3:16 am
Thought I'd get the intro post out of the way.
Name's Dave, I live in Fort Worth, but grew up in Indiana. Currently I have a 1gb Talon, but I finally found a good 89 Colt that I'm picking up tomorrow. I've been wanting to do a CSM build for probably 10 years now, and I couldn't pass up a 100$ Colt.
:finga:
I'll post some pictures up tomorrow when I get it to the house. As of yet, the only plan I have for the thing is to use the Talon as a donor for the swap, and then have some fun with it before I worry about anything else.
- Dave
PostPosted: Sun Sep 14, 2014 5:29 pm
Introducing the Colt to it's new habitat.
Blue interior. I kinda like it...
:D
The donor Talon.
PostPosted: Sun Sep 14, 2014 5:48 pm
welcome to the board.. nice looking car.
PostPosted: Sun Sep 14, 2014 5:51 pm
Thanks.
It has some minor cosmetic issues, none of which I care about. Trim and interior pieces I can replace easily, but there is a small dent in the hood, driver side fender, and the roof as well. For it's age, it's in very good shape.
I'm not looking to build a car that is slick looking anyway, I'm going for the "Econobeater" look.
PostPosted: Sun Sep 14, 2014 11:27 pm
Nice. Should be a fun project.
PostPosted: Sun Sep 14, 2014 11:32 pm
Welcome! Let's see some more pics of that DSM. It looks clean!
PostPosted: Sun Sep 14, 2014 11:59 pm
I hope so. I really can't wait to get started on it.
The picture is deceiving, it isn't that clean. It has a lot of hail damage, the paint is terrible, and there is some light passenger side body damage you can't see here. I was in the middle of pulling the engine for a rebuild when I bought the Colt, so it makes sense to use it as a parts car for this project. I'll own another 1g at some point, but I'm really looking for an Auto/AWD one.
It has been a lot of fun to drive and work on, and I will miss it until the Colt gets going.
I just recently had my phone brick on me, and couldn't salvage pictures that were on it. I'll take some tomorrow, though.
PostPosted: Mon Sep 15, 2014 10:02 am
Welcome to 61t! I've been keeping my eye open for a white csm for an auto/awd swap sometime in the future.
PostPosted: Mon Sep 15, 2014 8:08 pm
There's a couple of local guys with Auto/AWD 1g's that are ridicutarded fast for the power they make, I'm now pretty much sold on that combo. I would like to eventually AWD swap the Colt, build a 2.4, and throw an auto trans in there... but I'm nowhere near needing to worry about that. First things first, and all that. Maybe when the wife finishes nursing school and some money is freed up.
As requested, some pics of the DSM:
Not bad from this angle...
Engine is out with about another hour worth of work, which should happen in the next week (hopefully).
I drove it to work and used a pressure washer to degrease it before I parked it, so it's actually pretty clean in this picture.
That door cladding rattles a lot, it's broken and warped, and I'm not sure how it hasn't fallen off yet. You can also see the door/fender damage that is common for some reason.
You can clearly see the line where the clear coat stops, and where you can almost see bare metal through the paint between the wing and glass. Whole car is pretty much like this.
May not be very visible, but the roof looks a little like a whiffle ball with the hail damage.
The AC compressor was completely seized when I got it, and all the AC lines had been disconnected. All the knobs were missing, so I decided to use that spot for gauges. I got a cheapy boost gauge to check vac/wastegate pressure. Evo shift knob was in the car when I bought it.
Driving this car in the summer was... not fun.
When I bought it the guy told me the clutch was bad (true), but past that he didn't know what else was going on. The clutch was bad because the trans had backed off the block, and only the top two bolts were barely holding it on. Only one starter bolt was there as well. I ended up putting in new hardware, flywheel, clutch kit, lower control arms, inner/out tied rod ends, brakes and wheel bearings all the way around, both axles, new tires and wheels, flushed all the fluids, tune up, and did a complete timing job. I'm pretty sure I did a lot more, but I can't remember at this point.
It has basic mods; Prothane motor mounts, 3" exhaust, boost controller (was running 15 psi). It wasn't fast, but it was quick enough to be fun. I spent more time fixing it than modding it, and I still wasn't done with fixing it.
:o
I parked it because it was leaking oil from almost every seal and gasket except the head gasket. I was going to put it back in the Talon after I checked everything, and freshened up the engine. Clearly, not now.
Once I gut everything I want from the Talon, that's my first order of business.
PostPosted: Mon Sep 15, 2014 9:02 pm
Welcome to the board, I was wondering when you where going to make it over here.
PostPosted: Mon Sep 15, 2014 9:20 pm
Ah, hey man.
:D
I've known about the board for a long time, just never had cause to register. I was actually wondering when you'd pop in this thread lol.
PostPosted: Sat Sep 20, 2014 9:36 pm
Welp, got the motor pulled out of the Talon. I parked it on the stand in front of the Colt, so they can get used to each other for a bit.
I seriously need to clean out my garage, and build a workbench and some shelves. I think that's the next project before I start working on the Colt. It will make everything easier.
I still have some more work to do on the Talon in the driveway, so I can probably procrastinate on that for a little while longer.
PostPosted: Sun Nov 09, 2014 4:43 am
Slowly getting somewhere with this.
I finally got that workbench built. Seems to be working out well enough, and I only have about 200$ in it, mostly lumber.
Tore the engine down, found a lot of stuff I didn't want to find. It's going to set me back quite a bit in both time and cost.
Measured the crank, it was barely in spec, but would have to be at least polished if not machined. Lots of deep scratching, especially on the center main.
Luckily I found a short block locally for 150$, came with ARP head studs and rod bolts, front case and oil pump, all the timing components, and a good crank. Not bad.
So that's where I'm at. I'm hoping to have the motor back together and put away in the corner before Christmas, and then I can start prepping the Colt for the swap.
PostPosted: Sun Nov 09, 2014 11:31 am
Diggin the workspace and your organization :D
i notice the ice tray. Do you watch jafros videos?
PostPosted: Sun Nov 09, 2014 1:52 pm
Of course.
