It is currently Wed Apr 24, 2024 8:01 pm
Post new topic  Reply to topic  [ 109 posts ]  Go to page Previous 14 5 6 7 8 Next
PostPosted: Thu Aug 21, 2014 8:23 am
Couple hx40 pics.
Also my front engine mount cracked at the harbor freight weld. My original mount setup was strong but too tight and couldn't be removed. When I remade it all I had was the harbor freight welder. Didn't take much to rip those welds, when doing so both axles made contact with frame and damaged boots.
PostPosted: Tue Aug 26, 2014 6:06 am
$450 driveshaft :oops:
PostPosted: Fri Aug 29, 2014 8:12 am
Driveshaft turned out awesome. I like how you did the carrier bearing mount.
89 Original Turbo Colt Gt AWD PTE 6262 Built 9:1, TRE stage 2. 10.93@129
05 Evolution VIII FP Green, garage queen.
97 Eclipse Gsx 80k miles, 6 Bolt, HX-35
08 Ford F-350 6.4 PSD 3 mods and 600hp :)
PostPosted: Sat Aug 30, 2014 3:49 pm
First test launch. 35psi in the tires. 4link setup to not hit the rear tires very hard. 25psi wastegate spring for boost and nitrous on till 30mph. I hit 50mph in the vid.
http://youtu.be/rCcC1p8YxQ8
http://youtu.be/obRwxPyAZ34
PostPosted: Sat Aug 30, 2014 4:28 pm
ok now that its running and drivable you need to ship it over to me LOL...
but yeah great job man.. hopefully starting in oct I can start tinkering with mine again. finish up the front cross member swap I did.. and get the back cut out and the 8.8 in there before winter hits.
thanks for the boost of inspiration..
PostPosted: Sat Sep 06, 2014 11:55 am
Almost made it to the track lastnight but got rained out.
PostPosted: Sat Sep 06, 2014 6:37 pm
have you thought about using a vacuum pump out of a Volkswagen or Audi? This will give you the ability to hold lots of boost without pulling through your brakes.
PostPosted: Sat Sep 06, 2014 9:38 pm
I'm looking into the vac pump. It stayed still when fwd without one though.
PostPosted: Mon Sep 08, 2014 11:05 am
I used a SSBC Vacuum pump on my FWD. I will say be careful of holding too much back as you will start to strip the gears in the trans.
My best advice to you is to look into different friction material for the pads.
Warren
PostPosted: Wed Sep 10, 2014 11:03 pm
33psi shifting a bit early
35psi
PostPosted: Wed Sep 10, 2014 11:51 pm
Bad ass! Impressive weight for an AWD auto swap.
PostPosted: Thu Sep 11, 2014 6:13 am
very awesome sir congrats on running 9s
Warren
PostPosted: Thu Sep 11, 2014 8:33 am
Seen your video on FB, So badass, absolutely love this car!
PostPosted: Thu Sep 11, 2014 2:43 pm
Can you take a picture of how you attached the bracket for the throttle cable, since you relocated the throttlebody onto a pipe, inorder to clear the brake booster ?
Warren
PostPosted: Sat Sep 13, 2014 2:06 am
This is awesome.
Have you plotted the 4 link options yet? Where do you have it set now?
Users browsing this forum: No registered users and 72 guests
