It is currently Sat Apr 27, 2024 10:09 am
Post new topic  Reply to topic  [ 89 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Thu Jul 31, 2014 4:15 am
Any progress?
Also you need one of these
Image /shamelessplug
$750 for a basic harness? Considering the 20hp difference between carb'd LS and injected LS, that's a big pricey.
PostPosted: Thu Jul 31, 2014 9:22 am
You can easily make your own harness as well. $750 is crazy expensive. I see complete harnesses going for $300-400 for most swaps. Also, there may be only an initial 20hp gain between card and EFI, but once you want to start tuning and adding things like boost or nitrous, having EFI is obviously way, way better.
PostPosted: Thu Jul 31, 2014 3:02 pm
Carb'd ls intake, 260/new ebay, blowthrough carb 400/used, carb hat 100/used. I might be doing a boosted 5.3 into an FC as a next project, then use that motor in my Cutlass later on.
PostPosted: Thu Jul 31, 2014 3:33 pm
Carbs are for uncultured redneck swine. Get some class, mechacode!
PostPosted: Fri Aug 01, 2014 4:09 am
Found a guy that'll convert the harness into a standalone for 260. Now I need someone to buy my vert so I can go hardtop in dis biatch.
PostPosted: Sun Aug 03, 2014 10:47 pm
You could buy a cheaper harness but you will spend more time fixing it. I work for speartech, we fully test each harness on a running engine.
PostPosted: Tue Aug 12, 2014 8:42 am
Finding time to work on the car here and there. Got a killer deal on way too much clutch for the car-but for less than a monster stage one, I’ll grow into it. 
Image Image
And confirming what I already knew…
I hope to get some header wrap/high temp VHT/oil line parts this week do I can start final assembly of the turbo system. I hope t have it on the ground again and under its own power no later than Aug 30th.
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Tue Aug 12, 2014 8:47 am
Also pretty happy with the way the manifolds turned out. Had a tig lined up-but could not make it over to the shop so I went to town with the harbor freight Mig. Added bracing just to be safe.
Current
08 535ix 420awhp
PostPosted: Tue Aug 12, 2014 8:50 pm
Your harbor freight mig welds look much better than mine.
PostPosted: Wed Aug 13, 2014 1:30 am
Using gas with the welder I assume? About time you post some pics! My FC swap ideas are fading, found a guy that wants to trade something a little more mitsu related for mine.
PostPosted: Wed Aug 13, 2014 1:40 am
Yes, its just a HUGE POS! I am surprised it lasted more than a year or 2, now its year 10!! Stick with he FC! Just a great chassis.
One of these days I will pony up for something nice. Really, I am waiting to install 220v in the garage for a real welder.
Current
08 535ix 420awhp
PostPosted: Wed Aug 13, 2014 1:43 am
Made some more progress.
Spray bomb'd the manifolds with BBQ paint. "Baked" them in the sun. Tested the finish by trying to scratch it off with a screw driver. To my surprise-it did not come off.
Showing the brace, and the best a 10 year old harbor freight welder will weld. :(
Current
08 535ix 420awhp
PostPosted: Mon Sep 01, 2014 1:12 pm
She lives!
https://www.youtube.com/watch?v=L82XFXz-z2E
First fire. Runs/sounds great. Took a while to get the clutch to work, but we are all square now. Still needs a good brake bleed before she is back on the ground. I will also be doing a full review of these AWESOME turbos shortly. IMO these are a game changer in terms of value per dollar spent.
I am obviously undecided on the inter cooler. I am torn between A2A and A2W I have build a few of both set ups, but never used an A2W on my personal car.
Opinions?
Current
08 535ix 420awhp
PostPosted: Mon Sep 01, 2014 6:11 pm
I vote for a2a, a2w is a lot of weight to throw back into the car, sure there's plenty of power to make up for it but why bother.
PostPosted: Mon Sep 01, 2014 6:54 pm
You're gonna blow that thing up SO fast! :supz:
Users browsing this forum: No registered users and 140 guests
