If you can afford to have the shell dragged into a closed transport setup, then it will arrive at your door step, and you can haul it off with a truck. I can see this being very doable.
Shell is free with many parts correct?
Spending 1500 or more on transport, will land it right at your front door.
This is chump change to get a vehicle that is already build up, and the cage welded in properly.
The entry fee is far below the normal cost of racing .... anything!
Hell, maybe it will cost less. I'm just throwing out some numbers to put a reality check into the mix, and show just how feasible this is.
You can't buy a rust free shell, and cage, and weld it in for this cost. Let alone spend the time to engineer it, and pull it off with proper
execution.
Long live the free shell!!!
That is all.
