It is currently Sat Jun 15, 2024 10:38 pm
PostPosted: Fri Aug 08, 2014 7:24 am
Anybody know if fwd DSM rear struts will fit the CSM?
PostPosted: Fri Aug 08, 2014 9:22 am
Yes, they will physically bolt on, but your car will be about 2" lower in the rear because they are shorter. You would also need to press out the bottom bushing from your existing rear struts and press them into the DSM struts.
PostPosted: Fri Aug 08, 2014 7:01 pm
Tony, he said FWD DSM rear struts. Pretty sure they will raise the rear.
PostPosted: Fri Aug 08, 2014 7:48 pm
Oops, yeah, I missed that. That would raise the car a bit.
PostPosted: Fri Aug 08, 2014 7:51 pm
Just to clarify
awd dsm rear struts lower the car 2in
fwd dsm rear struts raise the car 2in?
94 Mitsubishi Mirage "4dr"
PostPosted: Fri Aug 08, 2014 8:05 pm
Just to clarify
No, the FWD DSM struts will not raise the rear 2". I don't know how much they'll raise the rear. I don't even know if anyone has ever tried installing them on a CSM before.
AWD DSM struts in the rear will make the car look like it's doing a massive AWD launch when it's just sitting still.
