It is currently Thu May 23, 2024 12:44 am
PostPosted: Sun Aug 03, 2014 6:37 pm
Well have logged a couple hundred miles on my 4g63t, tuning is going pretty good, letting the MS take care of most of it. The turbo I'm running currently is a Garret straight T3 from a older ford 2.3 with a 60 cold and 48 hotside. With the stock 4g turbos is it very easy to get into boost when leaving say a stop light? I find it almost impossible to not make 2-5# while driving easy. It's just been so long since I've driven a 4cyl car with a stockish sized turbo without a good bit of lag it seems weird.
PostPosted: Mon Aug 04, 2014 3:03 am
They boost up pretty quick until you slap on a bigger turbo. My old 14b was instant full boost, kind of miss it.
PostPosted: Mon Aug 04, 2014 9:23 am
That turbo is tiny, probably smaller than the stock 14b, so it's not surprising that it would always be spooling.
PostPosted: Mon Aug 04, 2014 4:56 pm
It looks huge next the the junked 14b I have out on the garage, I do have a 63 exhaust housing I can toss on it and see how that does. Rather keep it small than stick one of my bigger turbos on.
PostPosted: Mon Aug 04, 2014 7:35 pm
The housings might look bigger, but I'm pretty sure the wheels are smaller or at least a similar size to the 14b. Putting the .63 a/r housing on would help a lot, as the .48 is tiny and will choke off the 4G63 big time
