Well I got the other rotor and brake hardware kit, along with other misc things. Bled the brakes with a handy dandy brake vacuum pump bleeder which took like hour and a half or more I still dont think I got all the air out of the rear but I had some pedal and was egar to drive my baby.
Car drove great and shifted amazing. The steering wheel had some play though, it just wasnt tight. I think my front left wheel bearing is going bad but no noise it just has vertical play when tested. Not sure if my tie rods, ball joints or wheel bearings are bad or all 3.
Also my turn signals were acting funny, like but not really making a conecting behind the steering wheel or something. I would hear the clicking and sometimes it would turn into fast clicking like I have a bulb out but my 4 ways work fine. Very strange.
also my cursed windshield wiper internals keep coming separated which is very frustrating luckily enough my arm is just small enough to mess with it. It has come separated like 4 times. And im not an idiot that has their wipers on full bore when it sprinkling. If you know me im crazy about a few things on cars and door handles and wiper internals are something im mindful of.. but if anyone knows where I can get that plastic insert, im not sure if it has a part number but ill check tomorrow when im fixing it..
Lastly! I snapped a bolt...
its one of the two for the lower engine roll stop or mount. The thing where you jack up the front of your car.. yea, pop oops, ratchet with tire iron torque
. So I gotta get that out somehow and get another bolt..
Speaking of bolts when I was at the yard I pulled like 8 fender bolts. I have like 3 that have the heads busted off and probably 3 more will too. But im going to try to easy out them, and then drill with a small drill bit and hope it breaks loose or just drill it completely out but im trying to save the threads even though they could all use a run with a tap. I might try to barrow one. I think the 3g fender bolts ones are steel and 4gs are some alloy of other stuff. But I will still black rustoleom them b4 install
