It is currently Thu May 23, 2024 12:39 am
Post new topic  Reply to topic  [ 27 posts ]  Go to page 1 2 Next
PostPosted: Sun Jul 06, 2014 7:27 pm
As some you may know this car was gifted to me by Jeff aka duraldc. I am extremely honored to receive the car and have been spending many hours bringing this classic back to life. So far, with the help of Tony aka Debow, we have determined the engine is healthy with good compression. The spark plugs were extremely shot and gapped at roughly .080. The plug wires were jellow and it was missing a clamp on one of the ic pipes. We had to push start it to get it home but brought a trailer just incase. With these few changes the car starts right up with no issues. After all maintence was complete the car runs and drives ok. Also added some after market parts I had laying around.Most of my hours on the car have spent on wet sanding and cleaning, installing a new headlight and starting on some minor rust issues. Enough chit chat, here are some pics.
We later found out the exhaust cam was off one tooth.
Last edited by xxNocturnalxx on Tue Feb 23, 2016 12:57 pm, edited 3 times in total.
PostPosted: Sun Jul 06, 2014 8:58 pm
Nice and clean.
PostPosted: Sun Jul 06, 2014 10:22 pm
Glad to see this move on to another great home!
PostPosted: Mon Jul 07, 2014 7:50 am
If this turns out anything like your other car the PO no doubt made a wise choice giving it to you. Can't wait to see what you do with it.
PostPosted: Tue Jul 15, 2014 10:08 pm
Glad its going again!
PostPosted: Tue Jul 15, 2014 10:42 pm
yea he has put a lot of work into it already and it shows it looks 10 times better then it did. nice work man!
08 silverado max
91 Eagle Summit 4g63t swapped
PostPosted: Fri Jul 10, 2015 8:13 pm
Bit of an update.
Small 16g turbo done
Front mount and piping complete
Maft installed with GM maf
440cc injectors
90 Dsm EPROM ecu
Civic Half radiator located with hoses
PostPosted: Sun Jul 12, 2015 8:16 pm
Looks good man. What are the dimensions of that radiator? Trying to decide on one for my car.
PostPosted: Sun Jul 12, 2015 8:40 pm
It's just a civic radiator 92-99 or something like that. Just make sure to get the 3 row.
PostPosted: Sun Aug 09, 2015 6:57 pm
Progress..
Adding to the list:
ported evo3 manifold
Mishimito Front mount and piping complete
440cc injectors
90 Dsm EPROM ecu
Large SPAL fan with 185* wire kit
So far it idles great, test drive soon to follow.
PostPosted: Tue Aug 11, 2015 8:38 pm
So rad! Can I get a ride sometime? I could always use motivation to get mine running.
PostPosted: Tue Aug 11, 2015 11:17 pm
Sure, I live in Tacoma as well.
PostPosted: Sun Aug 16, 2015 12:19 pm
After getting everything back together and ready for a drive I decided to check the timing, the exhaust cam was off one tooth! Ended up carefully removing the cam gear while rotating to it's needed position, this took 4 hands but the car runs very smooth now and actually has some power. It's currently on spring pressure at about 8 psi. no issues to report and the Spal fan kit works amazing. Going to put the same kit on the Mirage if I can make a little more room. Once the old gas runs out we will turn the boost up a few lbs. and go from there. The new mustache bar is now paint matched along with the Grill. Bumper and hood work next.
PostPosted: Mon Aug 17, 2015 10:45 am
That was the old trick for getting more power up top with the 4g61t. Retarding the exhaust cam 1 tooth with stock cams, IIRC.
PostPosted: Mon Aug 17, 2015 11:34 am
I'm not sure which way is considered retard but the cam was rotated CCW, it definitely lacked power and rev speed at that time.
