It is currently Thu May 09, 2024 1:37 pm
Post new topic  Reply to topic  [ 19 posts ]  Go to page Previous 1 2
PostPosted: Tue Jun 17, 2014 5:37 pm
i suggest send them to who ever made them. IE: pti... rc...fic.
PostPosted: Thu Jun 19, 2014 12:30 am
Sounds like a shitty situation, best of luck hope the injectors work after cleaning! . I've sold a ton of parts and always honor refund within reasonable time frame because I attend alot of car meets, track, etc and you.never know when might see them again. The only problem here is the time frame. Whats to say someone wasn't enjoying them all along and then all sudden claim bad item? Personally used is used as long as working condition when sold, but there is a time limit. I can't refund a trans I sold 2 yrs ago, I waited a year to use a pressure plate I bought brand new, thing went bad after few months. It was a faulty PP, but I had swallow cost cause warranty was done.
PostPosted: Thu Jun 19, 2014 6:44 am
Considering that brand new performance parts frequently do not work right out of the box it should be no surprise that there was an issue with used injectors.
Had the injectors been brand new and you attempted to get your money back from a vendor 18 months after the purchase they would definitely have told you pound salt or to try your luck with the original manufacturer who would have probably told you to pound salt as these are performance parts.
These things happen.
This! Sorry but thats the truth.
PostPosted: Fri Jun 20, 2014 4:41 pm
Just a follow up. I talked to the guys at both PTE and Bosch and they said the issue with the injector is not caused by them sitting and an actual electrical issue inside the injector. I'm sending them into PTE to have them tested for verification. So just to clarify. You sold me an injector that never had a chance to work whether it sat around or not. My fault for not using them quick enough I guess. It would have been nice to even offer some help, but to each his own.
'92 Evo 1
'10 CTS-V
