It is currently Sat Apr 27, 2024 2:29 pm
PostPosted: Sun Jun 08, 2014 10:17 pm
Well I just bought a 90' colt that has a 4g63 swapped in. Car was originally a 1.5 non turbo car. Question is car has a aftermarket fan not hooked up just a 2 wire fan and was wondering how to wire it into the colt. I pulled up the colt wiring schematic and it shows there was a thermo switch on the factory fan that allowed it to kick on at certain temps. Was curious is someone could lead me in the right direction of how to wire this aftermarket fan properly.
Thanks
PostPosted: Mon Jun 09, 2014 6:11 am
Should be able to wire it into the stock wiring so the thermo switch can kick it on.
PostPosted: Mon Jun 09, 2014 6:14 am
Yes, the wire from the ECU is hot, and the one going to the temp sensor is GND.
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Mon Jun 09, 2014 9:44 am
Ok, I tested continuity from the relay terminals to a 4 pin connector by the driverside headlight. Can anyone tell me if this is the right connector the wire colors change but continuity is still the same. Wire colors on schematic also show a different color on one of the wires at the connector. Here is what I've found below to help understand what I looking at
Relay terminals wire colors - connector by headlight
-relay. Connector by headlight
Red/blue- Red/blue
Green/yellow- black
Green/black- Blue/yellow
Green/black- Green/black
PostPosted: Mon Jun 09, 2014 11:11 am
Should be on the passenger side. Drivers side would be the AC fan (if it was so equipped)
PostPosted: Mon Jun 09, 2014 11:21 am
On thanks, I'll take a look tonight when I get home.
PostPosted: Tue Jun 10, 2014 7:48 pm
Well guys I have them wired up and they run all the time. Any ideas on what you guys do and far as getting them to run at a certain temp.
I found the connector by the passenger headlight. I was originally on the a/c fan connector.
The car does not have a factory fan just a aftermarket fan spliced into the harness now.
PostPosted: Tue Jun 10, 2014 10:41 pm
if you look at this pic.. there are 2 plugs.. does yours fan/wiring have both of these? the black plug goes to near the PS headlight.. the smaller white plug goes to the temp switch that should be at the bottom of the radiator on the PS right next to where the lower hose connects.
https://encrypted-tbn2.gstatic.com/imag ... XLiQkiKJeF
cant really find any good pics of the sensor..but if u look here at the bottom (straight down from the upper rad hose) u can see where it plugs into... this tells the fan when to turn on.. it might be bad and thats why they hard wired it in..
http://i483.photobucket.com/albums/rr19 ... 2fecb2.jpg
PostPosted: Thu Jun 12, 2014 3:14 pm
Do they run with the key off? It's not that big of a deal if you wire them to key-on power.
PostPosted: Wed Feb 04, 2015 12:37 pm
Suggestion : before going too far , test your thermo switch.
https://www.youtube.com/watch?v=fQWQQr9EWMk
Dodge Colt 1992 4G63T -= Racing Car =-
Toyota Corolla S 2015 -= Daily Car =-
Mitsubishi Outlander V6 2009 -= Family Car =-
