It is currently Sun Jun 16, 2024 12:32 am
 Post subject: Mikey The Mirage
PostPosted: Fri May 30, 2014 1:24 am
Hey y'all,
Just picked me up a clean 1989 mirage. Still tuning mikey up, and making him road worthy, but check it out.
'89 Mirage turbo
 Post subject: Re: Mikey The Mirage
PostPosted: Fri May 30, 2014 9:35 am
Welcome to the forum! Please put a location in your profile. Also, your pics are tiny.
PostPosted: Fri May 30, 2014 10:32 am
Welcome from another newb. Yes, bigger pics please!
Brad D.
'80 Colt 1.6
'95 Mirage 1.8
PostPosted: Fri May 30, 2014 11:08 am
Does it have a cage in it? Looks kinda like Bosco's old car but it's hard to tell. Welcome!
PostPosted: Fri May 30, 2014 4:34 pm
Still not really sure how to put pictures on here. I'm surprised I even got small ones to work. Here's a list of my current mods, but I plan on taking Mikey to a whole knew level. Maybe one day ill even go 4 wheel (:
Admin edit-
Should look like this:
Code:
[img]http://imageshack.com/a/img834/4945/stnaq.jpg[/img]
'89 Mirage turbo
PostPosted: Fri May 30, 2014 4:35 pm
-Dodge SRT4 Frt Mount Intercooler
-EVO 3 16G Turbo, ceramic coated and ported
-Punishment Racing O2 housing
-Megan Racing 3" down pipe to 3" exhaust
-2G 609 Mass Air Flow Sensor
-K and N filter
-1G crushed Blow of valve
-1G non turbo throttle body
-EVO 8 550 cc injectors-
-no brand fuel pressure regulator
-CNT 255 lph fuel pump (rewired w/heavier gauge)
-AEM High flow Fuel filter (drop in replacement)
-Forced Performance Race Manifold
-Stainless Exhaust studs
-ARP Head studs
-Multi layer metal Head gasket
-New intake/exhaust gaskets
-coil on plug set up (300m Chrysler coil packs)
-A/C delete
-Jay Racing Alternator Relocation Kit
-Aluminum flywheel
-New OEM clutch
-Stainless Braided Clutch line
-Aluminum Radiator w/Slim Fan (electric)
-Optima Red top battery
-Galant VR4 slotted Brake Rotors
-'94 Mitsu Expo Spindles (knuckles)
-Stainless brake lines
-Prosport Air/Fuel Gauge
-Prosport Boost Gauge
-Several ECU options
-Apexi SAFE Fuel Tuner
-Trick, see through Timing Chain Valve Cover
'89 Mirage turbo
PostPosted: Sun Jun 01, 2014 7:37 pm
welcome
