It is currently Sat May 11, 2024 10:56 pm
 Post subject: Is 21 mpg normal?
PostPosted: Mon May 05, 2014 5:51 pm
So I have a 1995 Mirage Sedan 1.5l 3 speed auto. It passes emissions, new plugs and wires and replacement air filter. Car idles ok but is dreadfully slow. Worse off is I only get roughly 20mpg combined and 23 if I'm on the highway a lot. Is this normal for the 3 speed auto? If so what manual trans will bolt up to it? Only mods are 16" rims and HKS coilovers and the Evo III body
91 Talon TSi AWD- SOLD
91 Mirage 4dr 4G63T -Daily
facebook.com/modicausmc
 Post subject: Re: Is 21 mpg normal?
PostPosted: Mon May 05, 2014 6:09 pm
You should see in the 30s. Has the timing been checked?
PostPosted: Mon May 05, 2014 6:17 pm
Surprisingly I haven't. Hmmm I thought 21 was low but then again it is a 3 speed. I'll check. Any other reason it may be in case timing is on track? Would dirty injectors do it?havnt compression checked it either
PostPosted: Mon May 05, 2014 8:32 pm
Keep in mind, the higher your cruise RPM, the lower your economy. My 97 Ford Aspire 1.3 3-spd auto got 9L/100km (26mpg), and it was in top shape. At 100kph (60mph), it was turning nearly 3500 rpm :(. I shudder to think what my mpg would have been like at 65 or 70...
PostPosted: Mon May 05, 2014 8:38 pm
Will a f5m33 bolt up to the engine? I have one from my car being rebuilt
PostPosted: Tue May 06, 2014 1:51 am
3 Speed auto? Yeesh. If it's a 4gXX motor, any 4g trans should bolt up including 4 and 5 speeds.
PostPosted: Tue May 06, 2014 1:58 am
Excellent. I'll prob just throw a stock clutch and flywheel Assy on there and call it a day and say hello to lower cruise rpms and better gas mileage
PostPosted: Tue May 06, 2014 6:22 am
That should help. I get 35-38mpg hwy in my spare 1.5l colt, cruising @ 70-75 @ 3500rpm with a f5m31 tranny
PostPosted: Tue May 06, 2014 4:36 pm
I had one with the auto and I saw 41 every now and then, but average was about 33. It also shifted into third at 15mph if you allowed it, crazy low.
PostPosted: Wed May 07, 2014 1:52 pm
Okay guys changed plugs and 2,3,4 Looked nasty. #1 looked normal BECAUSE the plug wire was not clipped on. It had probably been misfiring for a while lol. Anyway going to check base timing either today or tomorrow. Car idles a little better after the plug change but still not right
PostPosted: Tue Jun 03, 2014 5:54 pm
Well I changed the thermostat because it was dicked, didnt seal at all, I didnt notice any fuel economy differences with the plugs but the thermostat yielded me 5 MORE MPG! now that it is running at opp temp. next is base timing and a new rotor cap since its probably original. ill update with my findings
PostPosted: Tue Jun 03, 2014 6:30 pm
If you want a little more pep in its step.
The Accel product I saw on ealier posts was good but it didn't last more than a year. And the colt died on the highway halfway between my house and Seattle. That was a joyous time I tell ya what!
When I get the colt all back together I will be switching the accel over to the msd ignition 8228 blaster replacement coil. You need the adapter to make it work buts its all easy.
---Coil---
http://www.amazon.com/MSD-Ignition-8228 ... 2GXXA0N831
---Adapter---
http://www.amazon.com/ACCEL-140021AH-Ig ... auto_img_y
if you need to look at the other posts there are some in the archives on other great tips on better performance and some of them actually gain you a little more MPG :)
~Ken
'91 Colt - Ongoing work in progress.
http://4g61t.org/forum/viewtopic.php?t=37446
^Check Build Thread^
'82 Chevy El Camino Tow Veh. for my 2012 Skyline Koala 24' Travel Trailer
'06 Chevy Aveo - Daily Driver until Colt is back up and running!
PostPosted: Tue Jun 03, 2014 11:58 pm
I appreciate the advice and links but I am just waiting for the engine to die so I can swap the forged 4G63 I'm building into her. To hell with gas mileage I'll have a 68HTA blowing away!!
PostPosted: Wed Jun 04, 2014 12:55 am
Well, atleast your in the right area for some nice tuning of that 4g63! :) Wish ya luck with the build make sure ya get some good pics as ya get her going and put it in the builds section!
~Ken
PostPosted: Wed Jun 04, 2014 1:00 am
Defiantly will. As soon as I start to finish the engine build I will start another build thread
