It is currently Fri May 03, 2024 2:52 pm
PostPosted: Wed Apr 23, 2014 6:42 pm
I have an issue with my headlights - the car failed the MOT for the full beam - when you pull the indicator stalk, the full beam comes on, but it doesn't stay on the full beam when the headlights are on, as it should.
I'm not sure if that's a problem with the stalk or maybe a relay or something - a look at the wiring diagrams should help me, if I can find them.
Anyone got them please? Thanks.
PostPosted: Wed Apr 23, 2014 7:33 pm
how does the lever/stalk feel? can u feel it click or lock into position when u pull it back.. if not then that might be the problem.. a broken tab on the plastic unit.
PostPosted: Thu Apr 24, 2014 3:06 am
send your email i will scan the wiring diagram amn send it to you
PostPosted: Thu Apr 24, 2014 3:08 am
just a question. by any chance do you have HID installed,?
PostPosted: Fri Apr 25, 2014 3:52 pm
I can't feel a positive 'click' - I wasn't sure if they did or not, it's been many years since I had one.
My email address is yeti@ayrshore.com.
And no HIDs... terrible things.
PostPosted: Sat Apr 26, 2014 7:26 am
wiring diagram sent. good luck
PostPosted: Sat Apr 26, 2014 3:18 pm
Looks like I'll be needing a new stalk. I'll take it off and have a look though - or maybe just wire a toggle switch to it for the MOT for now.
I fixed the electric mirrors earlier, which was a bonus.
PostPosted: Sun Apr 27, 2014 12:16 pm
Electric mirrors? Dude i have electric mirros and need to install them. Can you send me a pic(close one ) of the electric mirror conectors need to know how the wires goes in the connectors, the connectos just at the mirror
PostPosted: Sun Apr 27, 2014 3:37 pm
Everyone should know about this:
www.lilevo.com/mirage
PostPosted: Sun Apr 27, 2014 7:46 pm
Well my car came with electric mirrors, but they didn't work. When I lifted out the centre console, it became apparent why - the switch had the wrong connector on it, and wasn't connected. When I was routing the cable to power the amp yesterday, I found the correct electric window switch, which was physically damaged - so I took the two apart to make one working one with the right connector.
Nice link LILEVO, thanks. :)
PostPosted: Mon May 05, 2014 1:37 pm
Well I got another stalk, but the wires had been cut. I ended up repairing my own - the little metal pin the high/low switch pivots on had got rusty, that was all.
