It is currently Sun Apr 28, 2024 11:32 am
Post new topic  Reply to topic  [ 220 posts ]  Go to page Previous 110 11 12 13 14 15 Next
 Post subject: Re: big16g's awd thread
PostPosted: Mon Apr 21, 2014 5:20 pm
Ok thanks for the information... I currently have dsm knuckles with the regular colt control arms. the bump steer is horrendous. Sorry for the thread jack aaron
Sorry for the thread jack as well but this is for all of you on my colt ive got evo 4 control arms that bolt right on with evo 4 knuckles with evo Brembos and it all works great no bump steer at all. Check out my build below if you need any more info.
Sorry aaron
IRS awd evo3 rear floor colt check my build and tell me what you think
http://www.gsrcyborgclub.com/viewtopic. ... 952#p33952
PostPosted: Mon Apr 21, 2014 5:30 pm
You are good man, control arms are from 92-95 elantra.
PostPosted: Mon Apr 21, 2014 5:33 pm
Sorry aaron
You guys are good, always like hearing what everyone is running and don't mind answering questions.
I really like the idea of evo 4 stuff but we just dont have any of that stuff available to us in the states.
PostPosted: Mon Apr 21, 2014 7:23 pm
Are ok I didnt know that you dont have evo 4 gear over there.
Still it would not hard to find it. Its cheap in indonesia.
PostPosted: Sun May 18, 2014 9:19 pm
This is very inspirational.
11.9 is pretty quick but, I am curious though as to what the dyno numbers are and what it runs now? Also do you have a weight on the car?
PostPosted: Mon May 19, 2014 8:35 pm
Thanks man, the 11.9 was with the old 50trim I had and a slipping clutch. I haven't dynoed it yet with the new setup, should be next month until I can get to the dyno.
PostPosted: Tue May 20, 2014 8:37 pm
I wish you luck man and hope you do really well. I am interested to see how you do.
PostPosted: Fri Jul 04, 2014 2:42 pm
Finally got this heap going again! So last year I wasn't happy with the way the car drove on the suspension set up, it was really rough and uncomfortable. I ended up switching to a set of kyb gr2's up front and also swapped out to a set of expo knuckles to get rid of the bump steer. I am really happy with the way it drives now, it's a million times better. And of course I had to paint all the old parts lol.
Once again, I needed to make the car a little more comfortable to drive. I ended up selling my old kirkey economy drag seats and buying a set of Kirkey pros. They where a little bigger seats, but I was able to tweak the mounts I had and make them work.
Since I changed pretty much all the suspension up front I knew the car would need an alignment and I needed to test fit the slicks. I ended up raising the car about a 1/2 inch so they would clear.
At this point I was ready to fire the car, or so I though. Ended up having to chase down a few wiring gremlins. Once I got those sorted out the car fired right up even with switching to E85. And last Saturday I was able to drive the car and get a little driveablity tuning in with Wheatley. Happy with the way the car drove, I scheduled some dyno time over a Fathouse Fab. I was able to get in two days ago, which was way sooner than I expected. With about 10 miles on the car and not even hitting boost I was a little nervous it was going to have issues. I hadn't tested the boost controller so on the first pull on accident the car hit 38psi of boost, it wasn't a power hit so no numbers where recording but it sounded nasty and didn't blow up (I'm still on a stock 6-bolt). We switched to a hallman pro boost controller and let the car eat. I had an idea of where I wanted the car to be power wise, I wanted to keep it pretty conservative. I ended up stopping at 30psi and making 556hp's, even though everyone keep telling me to turn it up. :P
video of the dyno pull.
http://youtu.be/sy48ToeZOtI
PostPosted: Fri Jul 04, 2014 3:08 pm
Very nice! What axles are you using now that you have the elantra lca's on there? Think DSM AWD axles would work?
PostPosted: Fri Jul 04, 2014 3:59 pm
I'm using dsm axles.
PostPosted: Sun Jul 06, 2014 6:29 pm
Nice shit Aaron! With all those corn fields around Anderson you should have no problem finding fuel! harharharhar
PostPosted: Sun Jul 06, 2014 7:57 pm
woowwwwwwww that sounds awesome.. and its a lot of power
nice work aaron.
Warren
PostPosted: Thu Jul 24, 2014 3:42 am
That turbo spool is damn nice! Great build man love it
borg is on its way.....
PostPosted: Sun Jul 27, 2014 7:41 pm
Thanks dude!
PostPosted: Fri Aug 08, 2014 8:53 am
You doing shootout this year in the car (I assume trailer baby)? I am sure the car will grab a ton of attention. I saw your fb vid of the launch. Also, let me know when you want to move up to a wiseco piston, eagle rod, stock crank setup....I have a spare and if it sits in my possession for to long then I will sell it. It is just the short block and I have all the machining receipts. The machinest is top knotch where I come from.
92 Colt GT 4G63t
92 Summit TSI AWD 4G63t Auto
5 X 90 Talon TSI
90 GSX
Users browsing this forum: No registered users and 147 guests
