It is currently Sat Apr 27, 2024 3:51 am
 Post subject: 11.8 @ 125 My awd mirage
PostPosted: Mon Dec 23, 2013 1:40 am
Hey guys first of all car made 500 awhp on last Tuesday on a td06h 20g frame with a 35r compressor wheel. Went on Wednesday to my local dragstrip and went 11.8 granny shifting beacuse im having clutcg drag on a Quartermaster and the gears won't go at high rpms. Im really happy with how she did car is a low 11's With the proper shifting. Anyways heres the video and dyno graph.
BTW: let me know what you think about the goddamn clutchdrag on a twin disc.
http://youtu.be/fkG54AXdTSs
PostPosted: Mon Dec 23, 2013 2:22 am
very nice and grats... what gas are you running? pump or e85.
PostPosted: Mon Dec 23, 2013 2:48 am
Thanks!! It made 414 on 91 and 500 on C16
PostPosted: Mon Dec 23, 2013 7:21 am
Warped plates. Normal slip when city driving, they sometimes do not like from what anectodal stories I have read. Was the assembly used? How many miles since install? Daily driver?
PostPosted: Tue Dec 24, 2013 4:44 am
Clutch is new and car is not my DD. Planning on ordering the oem master and braided line from master to slave
PostPosted: Tue Dec 24, 2013 6:54 pm
Maybe not full dis-engagement due to weak older hyrdaulics. My trans shifted before clutch mods, but once the ACT was installed, I had to upgrade. Do you have a stainless clutch line setup? Highly recommended!
PostPosted: Tue Dec 24, 2013 8:48 pm
You only need a short length of braided for the piece in between the firewall and the slave.
In order to shift at high rpm consistently you really need an ignition/clutch switch interrupt. Can be done a few different ways.
Users browsing this forum: No registered users and 57 guests
