So still with the original tranny that came with my GT though it was rebuilt by TRE in 2007; and although the synchros are failing at high revs otherwise holding up well. Anyway, thinking of uprading to a heck of a deal used 3586 hta from my current fp green, and am wondering if the km210 can handle the extra 100 or so whp or will I need to switch to a F5M33 ?
It's not so much horsepower that kills trannies, it's torque. If you're making all your power up at high RPM's you're less likely to strip teeth off your gears, but you'll kill the synchros from all the high-RPM shifting. There aren't a lot of ways to win there. I say just run it until it pukes on you and then consider other options, or get the KM210 rebuilt now and put some stronger stuff in it while it's still basically in good shape.
