Finally getting around to working on the 1991 Dodge colt I have. It was an unfinished project when I got it, I'm pretty much down to paint and wiring.
It's getting an Megasquirt 1 setup using the stock cas and ignitors/coils/wires.... Got it assembled, tested, and a unterminated harness.
Printed out all the ecu pinouts a could find and headed to the car, only to find out nothing I had helped.
This is all I have hanging in the passenger kick panel.
Any ideas on what these are?
Also where would the starter relay be located if the car had one? Right now the starter is not hooked up and there is next to no quotes in the engine bay other than a fuse box on the passenger side fender.
Thanks
Randy
