It is currently Sat Jun 15, 2024 10:35 pm
 Post subject: Scirocco Rad
PostPosted: Fri Mar 22, 2013 9:25 am
Hey guys quick question,I nees to know what year of the Scirocco i need to order the radiator.
 Post subject: Re: Scirocco Rad
PostPosted: Fri Mar 22, 2013 3:26 pm
not sure of the years but this is the one I bought..but it was on sale at the time for 260.00.
http://www.summitracing.com/parts/AFC-80107N/
PostPosted: Sat Mar 23, 2013 5:06 pm
I believe I ordered mine for an 88. Got mine from parts geek.com I think I paid 58 bucks
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Mon Mar 25, 2013 9:00 am
Thanks guys,I'm trying to save up some space on the damn engine bay and with the Scirocco rad looks is the best option.
PostPosted: Fri Mar 29, 2013 4:43 am
Quick question..
Will this fit my Colt?
http://www.ebay.de/itm/WINNER-RACING-AL ... 1c2385c623
They ship to Croatia.. YaY... :drinkers:
PostPosted: Fri Mar 29, 2013 5:40 am
It's certainly not a bolt in application. With some cutting it will fit. Mine is where the ax condenser used to sit
2000 Lexus sc300
2016 ram 1500
PostPosted: Fri Mar 29, 2013 5:42 am
2000 Lexus sc300
2016 ram 1500
PostPosted: Tue Jul 23, 2013 10:44 pm
Do you happen to know EXACTLY which one you ordered?
Thanks!!
http://www.partsgeek.com/catalog/1988/v ... iator.html
PostPosted: Wed Jul 24, 2013 7:27 pm
Anyone knows the thread and size of the bottom bole??
PostPosted: Thu Jul 25, 2013 7:41 am
The radiator I bought from O'Reilly came with a threaded plug for that hole :) But, before I installed it I went to PAP and grabbed a few VW temp units from their radiators. I was going to use one just as a plug until I saw the radiator had one (the one I bought from Amazon and gave to my son was MUCH nicer than the O'Reilly's radiator, but did not come wit a plug.
PostPosted: Thu Jul 25, 2013 12:08 pm
Went to my local auto part and bougt a fan switch for a vw.Thanks!!!
PostPosted: Wed Jul 31, 2013 12:59 am
Which year did you all order for? Id love to fit mine like that and save the room.
PostPosted: Wed Jul 31, 2013 8:16 am
'88
PostPosted: Wed Jul 31, 2013 8:23 am
Sorry I'm a little slow. lol 88 Vw Scirocco? Did you get the metal one? How's that working out for you? I wanted to stay cost efficient, but wanted the aluminum or dual because was afraid of cooling issues, but the 58 bucks sounds great! Just checking, it kinda of messes me up, when the colt has parts from different years and makes. It's not as bad as my built eg I had.
PostPosted: Sat Feb 08, 2014 10:42 pm
If you're looking to use an actual replacement radiator for a Scirocco, 85-89 will all be the same.
What most people use are "Scirocco Style" aftermarket radiators. The best ones to work with are the full aluminum versions. That way, you can replace the undersized inlet and outlet to match the Mitsu sizing (the ones on the radiator are a bit smaller).
It also allows for easier mounting modifications, and adding/removing filler necks and sensor bungs--aluminum is just a lot easier to work with and install cleanly.
I actually have another style radiator coming in this week to see if I can cleanly mount it on my swapped C52a.
Josh
JNZ Tuning
