It is currently Thu May 02, 2024 7:06 pm
Post new topic  Reply to topic  [ 22 posts ]  Go to page Previous 1 2
PostPosted: Tue Jul 30, 2013 12:57 am
What specs did you end up getting?!
PostPosted: Tue Jul 30, 2013 3:36 am
15x7.4 40+ Rota Slips
Some MT ET streets 2
Picking up some 24.5 slicks also I was gonna try 26' but idk if they will clear
225's also all the way around
PostPosted: Tue Jul 30, 2013 4:21 am
Nice, I'm pretty sure 26" will hit quite a bit before lock.
PostPosted: Tue Jul 30, 2013 5:55 am
hmm talking on facebook & 61t are we?
PostPosted: Fri Aug 02, 2013 2:41 am
Yes, I am just so excited about your car :lol:
PostPosted: Sun Aug 04, 2013 4:29 pm
Lol so am I, I am waiting on my turbo feed & drain fittings, water to air setup, my 75mm TB, & all my SS line & fittings, then I can start putting it back together.
PostPosted: Mon Aug 12, 2013 9:55 pm
I figured I would ask this here instead of starting a new thread. With my fwd setup, I am running 17x8 +38. Currently they have 245 40 r17 and only scrub a little in the rear. The fenders are all rolled, but not pulled. Once the tires I have are done, 215 40 or 225 40 will replace them to make the overall diameter smaller, and to eliminate the scrubbing. My question is simple, when I install the AWD subframe, will I need higher offset wheels for the rear, or will the smaller tires and the ability for negative camber be enough. I only want to run 1-2 degrees negative in the rear.
