It is currently Thu Apr 18, 2024 11:52 pm
Post new topic  Reply to topic  [ 272 posts ]  Go to page Previous 112 13 14 15 1619 Next
 Post subject: Re: whe3ls's hyundai
PostPosted: Sun Jun 09, 2013 9:27 pm
here is a video
http://www.youtube.com/watch?feature=pl ... 693mXm1_LA
and a bought a new dd. its a 93-94 SHO. it needs a little work. it needs rear struts brakes front fender and a front bumper
PostPosted: Mon Jun 10, 2013 12:42 am
She's alive!! :D Good work man, and get that wastegate out of the radiator :wink:
PostPosted: Mon Jun 10, 2013 8:58 am
I haven't made the dump tube or the exhaust yet. I'm having a issue with the alt grounding when the power wire is bolted up, almost burned the car down. :(
PostPosted: Fri Jun 14, 2013 9:49 pm
Another video. Right before this I blew out the oil filter seal
https://www.youtube.com/watch?v=xtVc-qW ... ata_player
PostPosted: Fri Jun 14, 2013 11:11 pm
in gear start FTW lol :prayer:
PostPosted: Sat Jun 15, 2013 8:56 am
I forgot it was in drive when I started it. Oopps
PostPosted: Tue Jun 25, 2013 7:45 pm
https://www.youtube.com/watch?v=eErzLag ... ata_player
PostPosted: Tue Jun 25, 2013 8:49 pm
Braaap psssssssshhhhhhhhheeeeeeeeww 8)
PostPosted: Thu Jun 27, 2013 8:46 am
engine bay shot
PostPosted: Fri Jul 19, 2013 6:29 pm
been working on some wiring for the shift box. i need to order some more supplies.
shifter bottons
forced four gear display
next im going to finish my 1g dsm to evo patch harness
PostPosted: Thu Jul 25, 2013 3:22 pm
picked up a radiator fan, i still need to get a awd auto intermediate shaft and axle and expo knuckles and brakes. then i can save up for a meth kit.
im also working on the patch harness. what a pia....
PostPosted: Fri Jul 26, 2013 7:24 pm
getting closer to getting my patch harness done. about 8 more pins to finish. and then adding the evo connectors onto the other side.
PostPosted: Fri Jul 26, 2013 8:19 pm
The Evo ecu swap is awesome :). Check out dsmecu.com for waaaaaaaaaaaay better info on that swap than the long thread on DSM tuners.
Did you get your ecu yet?
PostPosted: Fri Jul 26, 2013 8:27 pm
i havent gotten the ecu yet. its still my list of parts to get. going to get everything shorted first
PostPosted: Fri Jul 26, 2013 10:07 pm
If you're not dead-set on ecu-controlled boost, then the 2001-2003 Eclipse M/T and 2002-2004 Lancer M/T ecus will work fine with the Evo 8 rom file. I have both, and each one runs my car exactly the same :).
You can also use the 2001-2004 A/T ecus, but there's a different wiring setup required, and a modded evo 8 rom is needed. My ecu of choice is a 2003 Lancer A/T, so I've got the file ;).
Also...it's not a well-known detail, but we discovered that you can use a $10 Ebay VAG-COM cable to flash the M/T ecus with Evoscan (there's a freebie flashing utility for the E8 and E9 cars). No need to splurge on any expensive cable. I've got a real cable, and a VAG-COM, and they both work the same.
